Old Sat, Jun-16-2018, 01:52:36 AM   #11
mrgizmo04
mrgizmo04's Avatar
Default Re: Random light throttle hiccup/stutter
Yeah a lot of bad gas around and it causes random issues!
Originally Posted by cmenard View Post
Had the exact symptoms and they would disappear for some time and come back again. Finally traced it to getting gas at a local BP. Now I just avoid that station, and use a Shell down the road. No more hiccups.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Jun-18-2018, 04:27:48 PM   #12
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
I chased a stutter/light throttle hesitation for a really long time with my car. I replaced the actuator, both TPS sensors (with sensors sent to me by TTFS), replaced the VANOS, cleaned the throttle bodies, replace the plugs, etc etc.
It started to get really bad just recently so I bought two new BMW OE TPS sensors, I installed the front one right away and ... night and day ... completely fixed the issue.
So my money is on the throttle position sensor(s).
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Mon, Jun-18-2018, 05:25:15 PM   #13
mrgizmo04
mrgizmo04's Avatar
With these cars all sensors should be bought OE. I know they are sometimes 2x expensive vs alternatives but they really pay for themselves when you don't have to chase random issues sometimes literally few days after installing the cheaper ones.
'05 M3 6MT coupe
Old Mon, Jun-18-2018, 07:12:04 PM   #14
cozmo kraemer
Yeah, it is really odd. The sensors sent to me by TTFS appeared to be OE BMW. I guess I just don't know their age. Replacing the sensor completely fixed the issue though, immediately. I will say that the CSL tune seems to be much, MUCH, more sensitive to throttle issues. With the MAF setup, it would have driven fine, but with the CSL you get the issues. The sensors really have to be top notch to make the setup work.
Now driving it, it is pretty incredible how much I was actually driving around the issue. You only really notice that once it is fixed.
My Journal
Old Mon, Jun-18-2018, 08:52:59 PM   #15
mrgizmo04
mrgizmo04's Avatar
Completely off topic, but before this post I'm writing, you and I had the same number of posts .
'05 M3 6MT coupe
Old Mon, Jun-18-2018, 09:56:04 PM   #16
cozmo kraemer
Ironic.... Only took me 8 years longer to get there! (looking at our join dates)
My Journal
Old Mon, Jun-18-2018, 09:59:35 PM   #17
mrgizmo04
mrgizmo04's Avatar
You are wise, you don't post as much nonsense as I do .
'05 M3 6MT coupe
Old Mon, Jun-18-2018, 10:59:08 PM   #18
silvergray545
silvergray545's Avatar
This is interesting. I replaced my top TPS with an OEM one. You could see where everything was ground off. I wonder if it's still subpar. Maybe I'll pick up a BMW sensor and give it a shot.
2004 BMW M3 6MT - TiAg/Gray
2016 BMW M3 ZCP 6MT - AW/SO
2014 VW GLI 6MT - Black/Black
Instagram
E46 M3 Build Journal
Jump to top silvergray545 is online now   Reply With Quote
Discussing Random light throttle hiccup/stutter in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
