Old Thu, May-31-2018, 06:30:35 AM   #41
I M Legend
Reputation: 0 I M Legend is on a distinguished road
Default Re: Cant pass smog test need help
I'm having the same issue. Hopefully the procedure works for me was well.
Jump to top I M Legend is offline   Reply With Quote
Old Thu, May-31-2018, 06:44:10 AM   #42
Good
@GOOD_M3
Good's Avatar
Reputation: 0 Good is on a distinguished road
Little late to the party, but what monitor isnít ready for you? Iíve been having an issue with my secondary monitor
2006 M3 Competition | Silver Grey Metallic
Modifications:
- Complete SuperSprint Exhaust: Stepped V1 Headers, Race Catted Sec 1, Resonated X-Pipe Sec 2, Sport (Gen 2) Sec 3.
- Karbonius CSL Airbox (Alpha N) w/ Flap and Oil Catch Can
- KW V2 w/ Ground Control Camber Plates
Preventative:
- Vanos Beisan Lockdown~ Upper Guide Chain, Solenoid Coil Pack, Oil Pump Disk
Jump to top Good is offline   Reply With Quote
Old Thu, May-31-2018, 04:39:48 PM   #43
I M Legend
not sure really. they just told me the catalyst is not ready and that I'll need to drive around some more and come back.
Old Mon, Jun-11-2018, 03:32:44 PM   #44
I M Legend
So I finally passed. I must've driven over 200 miles with no luck. Went for a couple of 15 minute drives at 55mph and still cats weren't ready. Finally realized I left the AC on. Turned it off the next day and went for the 3 minute drive and it passed!
Old Sat, Jun-16-2018, 05:51:47 AM   #45
VanosJan
Reputation: 0 VanosJan is on a distinguished road
Do I need to go on a 55MPH drive for 15 minutes right before getting it smogged? Or can I follow the procedure then get it smogged the next morning?
Jump to top VanosJan is offline   Reply With Quote
Old Tue, Jun-19-2018, 06:32:07 AM   #46
simon_c
Reputation: 0 simon_c is on a distinguished road
You can do the drive cycle the day before the smog check. It doesn't need to be on the way to the smog check place.
I'm having issue with the cat sensor in the not ready state (all others are in a ready state) I did 3 drive cycles at 50-60 mph for 15-20 min each (all under 3K rpms) and still not ready. I've driven 300 miles so far trying to get this thing to trigger but no dice yet. I hate putting mindless miles on the car like this.
2004 M3 - Alpine White | Impluse Cloth | 6MT
2002 M3 - Alpine White | Cinnamon | 6MT (past)
Jump to top simon_c is offline   Reply With Quote
Old Tue, Jun-19-2018, 01:23:37 PM   #47
I M Legend
Do the 3 minute drive as stated in the original instructions. Like you I did the 15 minute drive but it didn't work.
Sent from my R1 HD using Tapatalk
Old Tue, Jun-19-2018, 10:59:03 PM   #48
simon_c
Is this what you're talking about in terms of the 3 min drive?
- Hold at a steady speed of 55 mph for three minutes.
- Decelerate (coast down) to 20 mph without braking or depressing the clutch.
or this:
http://www.instructables.com/id/How-...or-Smog-Check/
Old Tue, Jun-19-2018, 11:19:31 PM   #49
I M Legend
or this:
I held steady at around 55-60 mph for about 3 minutes. Exited the freeway slowly then just got back on and went back the way I came. Remember you have to start from cold. So I woke up in the morning and casually drove to the freeway. Did the 3 min drive then came back. Don't rev past 4K RPM if possible on your way to the freeway. Keep the AC off. That's what worked for me. Goodluck
Old Wed, Jun-20-2018, 06:30:26 AM   #50
simon_c
So I just got back from another unsuccessful drive cycle attempt for the CAT readiness.
I did 2 attempts of the following:
- 50-55mph for 3-4 min, never exceeding 60mph, never exceeding 3k rpms, and never touching the brake pedal
I also did two attempts of the following:
- 50-55mph for 15-17 min never exceeding 60mph, never exceeding 3k rpms, and never touching the brake pedal
Still no nice for me and this is my 6th drive cycle. Unfortunately for me my steering wheel buttons aren't working right now so no ability to use cruise control. Using an OBD2 scanner (autolink AL319) and CAT still shows not ready.
Not sure what else to do at this point as my registration is due on Friday. What am I doing wrong?
Discussing Cant pass smog test need help in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
