Old Sun, Jun-17-2018, 07:06:51 PM   #1
Holstad
Reputation: 0 Holstad is on a distinguished road
Norway
Default Evosport Pulley Kit
Hi,
I'm hoping that someone in the community can help me out with a problem I've currently got.
I've been running the Evosport performace pulley kit (water pump, power steering pump and alternator) on my car for years, and it's been working flawlessly.
A little while ago I had to replace my alternator, and took the cheap way out and bought a non-OEM unit and installed it in the car.
The unit was bolt on, but on the time of installation I didn't realize that the replacement alternator had a slightly longer axle than the OEM, resulting in the alternator pulley to stick out barely 4mm longer (1/6") than the rest of the pulleys.
No need to explain - over a bit of time this has resulted in a damaged pulley (worn down knife-edge on the inner side of the pulley) and torn serpentine belt.
As there is no retailer for this kit in Norway, I've been trying to get in contact with some US-suppliers without luck.
I'm replacing the alternator with OEM and OEM pulley again.
Now seeing that these kits are sold without the alternator pulley, i was hoping that someone could tell me the what length of the serpentine belt supplied with these kits are (water pump and power steering pump only). For info the belt i had supplied with my kit was a 6 PK 1538, so i would expect it to be slightly shorter...
Any help would be greatly appreciated and thanks in advance guys!
-02 TiAg Euro M3 SMG
ESS Tune|OEM CSL Rims w/PS4S|OEM 18" Rims w/PS CUP|OEM CSL Bootlid|OEM CSL Rear Camber arms|OEM CSL Brake upgrade|OEM LED Tail Lights|CSL Diffusor|Goodridge Brake Hoses|Hartge Pedals|Custom Interior Trim|Vörsteiner CF Engine Cover|TMS Carbon intake (front)|K&N 57i intake|AC Schnitzer Front Strut Brace|Evosport Performance Pulley Kit|Custom built Ferrita Race Exhaust w/HJS 100 cells Race Cats & Non-Resonated X-Pipe|WeissLicht Angel eyes|Titanium Line Headlight Trim|Philips Blue Vision High Beams & Fogs|Philips Silver Vision Front Corners|KW v3 Coilovers|MK IV Navi Upgrade w/Speedcam Alert|313 RWHP / 256 lb.ft RWT
Jump to top Holstad is offline   Reply With Quote
Old Sun, Jun-17-2018, 10:11:01 PM   #2
R1pilot
Reputation: 0 R1pilot is on a distinguished road
Default Re: Evosport Pulley Kit
I believe the 1538 part tells you the length in mm.
I would go to a parts store and see if they have a 6pk and a smaller number. You can take a piece of string, route it as a belt and then measure the length also.
Hope this helps somewhat.
Jump to top R1pilot is offline   Reply With Quote
Old Sun, Jun-17-2018, 10:45:05 PM   #3
erickrayos
Reputation: 0 erickrayos is on a distinguished road
yes 1538 is the length in mm. Funny thing is my UUC kit comes w/ 1540mm and its the one w/o the alternator pulley.
Jump to top erickrayos is online now   Reply With Quote
Old Mon, Jun-18-2018, 01:40:06 AM   #4
Holstad
Norway
Yes, was thinking about pulling a string or piece of thread around to see the length...should still be a bit of room for the belt tensioner to work on, so maybe this will be no issue what so ever. Thanks though
Old Mon, Jun-18-2018, 01:43:20 AM   #5
Holstad
Norway
Yes, I've also seen pictures of two piece kits with either 1538 or 1540 belts, so was in doubt if this was just for illustration only or if it was the actual belt supplied with the kit. UUC may run bigger diameter pulleys on their kits, but that's beyond my knowledge.
I see next step down on Contitech's belts are 1515, so might not be so bad. Thanks
Old Thu, Jun-28-2018, 09:26:57 PM   #6
Holstad
Norway
FYI; 6 PK1538 fits like a glove
Old Thu, Jun-28-2018, 09:43:18 PM   #7
Yes, that's the one I use with RE kit. Keep in mind, the tensioner will pick up any slack, so a belt doesn't have to be exactly 1538mm, but within a range that can be accommodated by the tensioner.
1540mm would be fine too. As 1536 would or some other number within several mms, I imagine.
The number before the length, e.i. "6"pk refers to the ribs, so 5 for a/c belt (829mm length fyi) and 6 for assec. drive (stock is like 14xxmm).
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/600) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Discussing Evosport Pulley Kit in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
