Old Tue, Jan-14-2020, 09:08:04 PM   #1
E36E46Eb
Reputation: 0 E36E46Eb is on a distinguished road
Default Seeking suggestions for upgrade clutch replacement SMG track only M3
Before you might be tempted to recommend a full SMG to 6 sp conversion, I canít. I am a disabled driver, and just donít have enough available limbs to operate everything a standard setup demands. When the Ferrari F1, BMW SMG, PDK, etc., became a viable option, Iím all over it and must stick with it.
My clutch is old and slipping after an SMG shift, even with lifting, so itís time to replace it. Turner, Bimmerworld, and others offer several levels of clutch upgrades, but all seem to be for the ď6 SPD MT onlyĒ, does anyone know of a robust clutch upgrade for a factory SMG, that will remain SMG? Thanks
Jump to top E36E46Eb is offline   Reply With Quote
Old Tue, Jan-14-2020, 09:31:32 PM   #2
Steve M3
Default Re: Seeking suggestions for upgrade clutch replacement SMG track only M3
How many miles are on the car and how much power does it make above stock?
If the car isn't highly modified, I would just do another OE clutch and call it a day.
Jump to top Steve M3 is online now   Reply With Quote
Old Tue, Jan-14-2020, 09:47:08 PM   #3
New stock is your best bet.
Old Tue, Jan-14-2020, 11:16:44 PM   #4
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
Agreed, even with slightly elevated whp, we run stock in the SMG endurance race car, the clutch never gives us an issue.
Current Garage... '00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT, '00 Black 323iT (wife's), '02 Alpine 325iT (Eileen, Track Wagon), '02 Japan Rot 325iT, '04 Gray 325iT, '04 IR ZHP Sedan
Instagram @ HillPerformanceBimmers
Email to George@HillPerformance.com
Jump to top GeorgeH is offline   Reply With Quote
Old Thu, Jan-16-2020, 08:45:23 PM   #5
E36E46Eb
Ok, looks like the overwhelming reccomendation is to stick with the OE setup. To answer the mods question, absolutely nothing to the factory engine and drivetrain, which show 160K mi indicated, and I have no idea what level of replacement of wearable items has taken place, but before the next track event am addressing the clutch and probably the main bearing issue to prevent gernading.
Really, as far as developing the car, I just plan to lighten the car and add aero as needed per race rules, and perhaps some light engine mods, again, per rules, cold air, possible ring & pin swap later. Any bang for buck suggestions welcome, and remember, it's a track only car so comfort and practicality are not in the picture. Thx much!!
Old Fri, Jan-17-2020, 11:26:27 PM   #6
eacmen
FYI SMG would need tuning or coding for a lightweight flywheel and clutch. Not aware of a DIY out there for making those modifications.
I had a tilton triple disc clutch in our 6MT and it was one of the best track mods we ever made. We now have an SMG and when the time comes well be using the OEM clutch and fw.
After you change the clutch you will have to run the SMG adaptations via DIS or something similar. Might also be a good time to flush the SMG fluid.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Sat, Jan-18-2020, 02:25:58 AM   #7
GrendelsbaneM3
GrendelsbaneM3's Avatar
Reputation: 0 GrendelsbaneM3 is on a distinguished road
FCP has the Luk Clutch kit for $317.29. https://www.fcpeuro.com/products/bmw...uk-21212282667 I used that one before getting the Clutchmaster FX400.
2004 Silver M3 / SMG / TC Kline DA Coilovers / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / ALPS Jammers / Clear Bumper Reflectors / Zionsville Competition Cooling Kit with Offset Fan / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune / ESS 575 Supercharger / Stillen AP Racing BBK / J-Fiber Carbon Fiber Driveshaft
Jump to top GrendelsbaneM3 is offline   Reply With Quote
Old Mon, Jan-20-2020, 05:53:05 PM   #8
GeorgeH
BMW Fan
Sent you a PM
clutch, racing, smg, track
Discussing Seeking suggestions for upgrade clutch replacement SMG track only M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
