Old Wed, Jan-08-2020, 03:39:09 PM   #1
Acqui
Reputation: 0 Acqui is on a distinguished road
Default A great interview!
Jump to top Acqui is offline   Reply With Quote
Old Wed, Jan-08-2020, 06:24:54 PM   #2
Default Re: A great interview!
Podcast version:
https://podcasts.apple.com/us/podcas...=1000461888039
Old Thu, Jan-09-2020, 07:27:16 PM   #3
Somewhere between 40 and 50 minutes (was listening while driving), he mentions that the turbo M engines were 100% a cost saving measure forced on the M division by BMW, that the M division was against.
Old Thu, Jan-09-2020, 07:39:47 PM   #4
or to meet MPG/emissions rules was my main guess
Eibach Pro-kit springs & sways Koni STR.T Whiteline SFB Dinan camber plates M3 FCA
Old Thu, Jan-09-2020, 07:57:00 PM   #5
Head of M from when it happened says cost savings.
Old Fri, Jan-10-2020, 02:25:39 AM   #6
hammerfang
Reputation: 0 hammerfang is on a distinguished road
Would be awesome if BMW make a high specific output N/A motor on a limited production car similar to what Porsche does. Sadly I don't think they even make an N/A motor anymore.
Purely out of curiosity, I wonder if you could take an M2 CS with the S55 and "de-turbo" into an N/A motor? Technology has come a long way since the S54, would be interesting what could be done today from the factory...
Jump to top hammerfang is offline   Reply With Quote
Old Fri, Jan-10-2020, 05:42:56 AM   #7
e30will
Reputation: 0 e30will has disabled reputation
He's at Hyundai now, I believe. It'll be interesting to see how Hyundai's product line changes.
Jump to top e30will is offline   Reply With Quote
Old Fri, Jan-10-2020, 02:51:35 PM   #8
jbfrancis3
Reputation: 0 jbfrancis3 is on a distinguished road
If cost were not an issue, it would be still be difficult to imagine BMW not turning to turbocharging. You see many of the technically capable OEMs have already moved to it.
'05 M3 Convertible 6MT, Carbon Black/Cinnamon, Karbonius CSL Airbox, OEM Flap, Kassel CSL Conversion w/ Kassel MAP Sensor, Schrick 288/280 w/ DLC rockers, CPI Single Stepped Headers, KW Variant 2.
Jump to top jbfrancis3 is offline   Reply With Quote
Old Fri, Jan-10-2020, 03:04:31 PM   #9
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
Another interesting thing as well was, in a way, he said the new M engine are not real M engines.
Makes me a lot sadder about the era being over.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable 500lbs Front 600lbs Rear/TCKline Camber Plates/Turner Adjustable Rear Control Arm/Turner Monoball RTABs/Turner Monoball FCABS/ Whiteline Front Sway / Brembo GT 6 piston Front 4 Piston Rear/OEM CSL Trunk/ CSL rep 1 piece lip
Jump to top Sandeep1212 is offline   Reply With Quote
Old Fri, Jan-10-2020, 03:11:28 PM   #10
I never had any doubt
Discussing A great interview! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
