Old Thu, Sep-15-2011, 10:29:02 PM   #51
Z3MCOUPE
Gort! Klaatu barada nikto.
Z3MCOUPE's Avatar
Reputation: 0 Z3MCOUPE is on a distinguished road
Default Re: How to tighten E46 M3 side mirror?
Thanks for all the info. Doing this tomorrow!
2000 Z3 MCoupe, '01 LSB E46 M3, '99 VW GTI VR6, '06 Audi A4 2.0T,
Andrew (camdinans3) '95 M3 Avus
Jump to top Z3MCOUPE is offline   Reply With Quote
Old Sat, Sep-17-2011, 01:29:20 AM   #52
OldFanatic
19 yr BMWCCA Member
OldFanatic's Avatar
Reputation: 0 OldFanatic is on a distinguished road
yikes, did this some 7 yrs ago. and you don't have to break the mirror glass taking it off or tear the surface panel off the glass motor. if the arm is tight to the body you may be one of the ones where the housing is loose to the arm.
there are two types of mirror backings. one where it has a retaining ring that move side to side to lock into place(pic #3). the other has clips that press and lock onto the motor side(pic #4). there is also some double sided tape that adheres, so gently pull for those after un-cliping/un-locking. (4th photo shows my own tape added) For those that un-clip, when removing the glass, press the top or bottom of the glass in so you can access behind it. use a wooden spoon at either 12 o'clock or 6 o'clock position. not on the sides, that will crack it. for the type that's pic #3 the locking-ring one. to remove: press the top glass in so you'll be able to view the slot for the locking ring at the other bottom side at about 6 o'clock position. using a slotted screwdriver in the ring slot slide it right (maybe left) and it'll unlock. if the white backing tape is holding it still gently rock/work it with a wooden spoon until it comes off.
now after the glass is off you'll see the motor. remove these with torx screwdriver, i think it's three on the edges(not the middle one). then you'll see the shield(infront/behind) this is where you can see the other torx screws that hold the arm to the housing. if these are loose tighten them and the tear drop mirror housing will become firm again. here are a few photos of what to expect after the motor and shield inside.
2003 TiAg - OE CSL WHEELS - OE CSL BRAKES - AA SPORT TUNE - AA PULLEYS - AS 40% SSK- VCSL TRUNK - VCSL DIFFUSER
SUPERSPRINT EXHAUST
- BMW PERFORMANCE CF STRUT BRACE - BILSTEIN PSS9s - GRUPPE M CF INTAKE - CF RACE LIP - 4.10 M DIFF - CSL RACK - GROUP N MOTORMOUNTS
-SANS SUNROOF-
Jump to top OldFanatic is offline   Reply With Quote
Old Sat, Jan-14-2012, 05:12:47 PM   #53
bdp21xls
bdp21xls's Avatar
Reputation: 0 bdp21xls is on a distinguished road
Good info. I just pulled mine apart (driver's side). Came apart no problems! The locking ring, at least on the driver's side, rotates RIGHT. Also, a suggestion...use heat to soften up the double-sided adhesive. Either a heat gun, or I just put a halogen worklight in front of the mirror for half an hour before I pulled it apart. Good to go!
2001 Alpine White, 67k, 6MT, convertible. Koni Sports, RE RSMs, PF RTABs, EAS Angel Eyes, Alpine audio, Aero AR-20, blackout grills, AP V2 Headers, Evolve tune.
Jump to top bdp21xls is offline   Reply With Quote
Old Mon, Jan-30-2012, 03:31:29 AM   #54
Mr. Vapor
Mr. Vapor's Avatar
Reputation: 0 Mr. Vapor is on a distinguished road
If I unscrew the torx bits completely, can I remove my mirror housing? I want to experiment with some things that will require me to drop off the housing at a shop for a few days
2006 M3 - Competition Package - Carbon black [Nav] [M-DSC] [HK] [ZPP] [ZCP]
[Evolve-R] [Supersprint Race] [Evosport SS headers] [CPI Euro200R] [Powerflex RTABs] [RE RSMs] [FK Silverline Plus X coilovers] [AFE Intake Arm] [Black kidneys/grilles] [Smoked corner lights] [Powdercoated 19" CSL ] [235/265 CSL spec Potenza Pole Positions] [Smoked reflectors] [30% tint] [Iconz CF 1-piece race lip] [RPI Scoops]
Jump to top Mr. Vapor is offline   Reply With Quote
Old Tue, Mar-13-2012, 03:59:27 AM   #55
rlddlr53
Reputation: 0 rlddlr53 is on a distinguished road
Just did this 5 minutes ago!
Jump to top rlddlr53 is offline   Reply With Quote
Old Tue, Mar-13-2012, 04:15:29 AM   #56
5ABIVT
Reputation: 0 5ABIVT is on a distinguished road
Nice I need to do this as well.. 03.5 both loose
Jump to top 5ABIVT is offline   Reply With Quote
Old Sun, Aug-31-2014, 10:05:43 PM   #57
SeattleM3PO
Reputation: 0 SeattleM3PO is on a distinguished road
Adding my "Thank you" to this thread.
My mirror and the housing around the mirror were loose (drivers side). Bugged me and I could envision disaster as my mirror fell off on the freeway!
Thankfully I found this thread and in less than 10 minutes my mirror was secure again.
Jump to top SeattleM3PO is offline   Reply With Quote
Old Thu, Aug-03-2017, 02:40:49 AM   #58
MFNATIK
Reputation: 0 MFNATIK is on a distinguished road
Great thread! Fixed both my "loose" mirror housings that jiggled over every bump.
2005 Imola M3 Convertible
2017 LSB F80
2017 Protonic Blue i3REx
2002 525iT M Sport
Jump to top MFNATIK is offline   Reply With Quote
e46, mirror, side, tighten
WTB: Passenger side Mirror M3 E46 ranchero Parts for Sale/Wanted 2 Mon, Jun-16-2008 11:51:01 PM
wtb E46 driver side mirror summy Parts for Sale/Wanted 5 Wed, Dec-20-2006 08:16:57 PM
wtb E46 driver side mirror summy Southeast 0 Tue, Dec-19-2006 07:43:20 PM
How do you remove E46 M3 side mirror glass? greg328 E46 M3 (2001-2006) 20 Sat, Dec-02-2006 11:42:16 PM
FS: E46 M3 passenger side mirror insert brettm3 Parts for Sale/Wanted 7 Fri, Nov-24-2006 04:11:34 PM
Discussing How to tighten E46 M3 side mirror? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
