Old Wed, Jan-21-2009, 08:27:53 PM   #41
bmwfool
Reputation: 0 bmwfool is on a distinguished road
Thanks to this thread, I was able to fix my mirror. I used Loctite, so hopefully it won't work its way loose again.
Thanks for the help!
~bmwfool~
'04 M3!
FK suspension.
RD2 rims.
(OO (|||)(|||) OO)
Jump to top bmwfool is offline   Reply With Quote
Old Wed, Jan-21-2009, 09:02:20 PM   #42
Knolly
Knolly's Avatar
Reputation: 0 Knolly is on a distinguished road
Great thread - I have a '02 and both sides are loose (the housings....) thought it was just mine - now I have the fix... Great forum full of great insight for those of us lurking in the background...
Jump to top Knolly is offline   Reply With Quote
Old Thu, Apr-02-2009, 02:57:11 AM   #43
Matthew C Smith
Reputation: 0 Matthew C Smith is on a distinguished road
Thanks for the info and pictures.
I removed the mirror glass in mine (6/03 build date) for replacement. The mirror glass in mine is just as pictured above. The ETK lists the later style of clip in glass 51167157247.
Does anyone know the part number for the rotating retainer with the double stick tape as pictured?
Jump to top Matthew C Smith is offline   Reply With Quote
Old Sun, May-01-2011, 05:03:59 PM   #44
taosx5
Reputation: 0 taosx5 is on a distinguished road
Default Re: How to tighten E46 M3 side mirror?
I just did this on my driver side mirror. A couple of obervations for any one who attempts to do this. First when you pop off the plastic triangle, be careful because it is fragile and you can break one or both of the plastic push tabs. Simpley pop the top corner towards the steering wheel gently, once the top plastic push tab is out, you can look in to see what you are dealing with. Then gently pull the entire plastic piece as one up and out being careful not to break the second push tab. The two hex bolts you need to remove are 10mm. Make sure you have some type of towel or something to lay between the door and the mirror so you don't scratch either one. Take the black triangle mirror seal off to expose the two torx heads. The torx is a T-20. It is a little tight quarters so make sure you don't drop the T-20 into one of the openings in the door panel. Tighten with some lock tite or with lock washer as mentioned in this thread and viola, ready to go.
Great thread btw. This forum is very helpful to non-mechanical types like myself.
Jump to top taosx5 is offline   Reply With Quote
Old Sun, May-01-2011, 07:02:14 PM   #45
NikolaiD
NikolaiD's Avatar
Bulgaria
http://www.chitownm.com/forums/showthread.php?t=3496
MSS54 Error Codes
(work in progress)
Old Thu, Sep-15-2011, 04:38:15 AM   #46
gazosnic
Reputation: 0 gazosnic is on a distinguished road
Originally Posted by NikolaiD View Post
I just did this when i got home after the meet.... Thanks for posting... was a easy fix.
Jump to top gazosnic is offline   Reply With Quote
Old Thu, Sep-15-2011, 01:55:31 PM   #47
MikeS123
Reputation: 0 MikeS123 is on a distinguished road
Glad I found this thread. Unfortunately, I think mine is suffering from both symptoms (housing and glass loose). I'll try tightening to see if that helps, but where is the best place to buy the glass and actuator if I need to replace them? Tischer? I did not know if there are any glass places out there like there are to repair our rearview mirrors.
Jump to top MikeS123 is offline   Reply With Quote
Old Thu, Sep-15-2011, 02:50:09 PM   #48
dsm918
dsm918's Avatar
Reputation: 0 dsm918 is on a distinguished road
That is exact same problem I've had. Thanks for the link. Looks like a super easy fix
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
00 GSXR 600 (Track Star)
90 Nissan 300ZXTT
92 Eclipse GSX - 11.841 @ 117.11
Jump to top dsm918 is offline   Reply With Quote
Old Thu, Sep-15-2011, 03:48:36 PM   #49
Cuz5150
Cuz5150
Cuz5150's Avatar
Reputation: 0 Cuz5150 is on a distinguished road
I too have an 04 with the drivers side mirror problem.
I just walked out side in my garage and fixed it in 10min.
Thanks to this thread!!!
Used some red loctite and lets hope it never happens again.
http://im1.shutterfly.com/media/47a3cc29b3127ccef48539c87df200000030O00AaNHDJi0YuG  IPbz4a/cC/f%3D0/ls%3D00108141284420131209001350520.JPG/ps%3D50/r%3D0/rx%3D550/ry%3D400/
2007 Z4 Coupe/Black/Black/6mt/Premium/Xenon
2004/M3/Vert/Black/Imola/6mt/Cold/Xenon/HK
2006/M3/Coupe/Mystic/Black/6mt/ZCP/Xenon/HK
2009/135i/Coupe/Alpine/Black/6mt/M-sport/Idrive-sold
2002 998 Ducati-sold
-Diplomacy is saying "nice doggie" while trying to find a rock
Jump to top Cuz5150 is offline   Reply With Quote
Old Thu, Sep-15-2011, 10:17:09 PM   #50
stewy612
GO DAWGS
stewy612's Avatar
Reputation: 0 stewy612 is on a distinguished road
thanks for the thread! doing this tomorrow! my whole housing rattles around...
anyone know whats up with my passenger side power mirror only moving side to side and not up and down when i try to adjust it?
-Brett
2001 Oxford l Cinnamon Vert 6MT
Jump to top stewy612 is offline   Reply With Quote
e46, mirror, side, tighten
WTB: Passenger side Mirror M3 E46 ranchero Parts for Sale/Wanted 2 Mon, Jun-16-2008 11:51:01 PM
wtb E46 driver side mirror summy Parts for Sale/Wanted 5 Wed, Dec-20-2006 08:16:57 PM
wtb E46 driver side mirror summy Southeast 0 Tue, Dec-19-2006 07:43:20 PM
How do you remove E46 M3 side mirror glass? greg328 E46 M3 (2001-2006) 20 Sat, Dec-02-2006 11:42:16 PM
FS: E46 M3 passenger side mirror insert brettm3 Parts for Sale/Wanted 7 Fri, Nov-24-2006 04:11:34 PM
Discussing How to tighten E46 M3 side mirror? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
