Old Thu, May-04-2006, 02:52:51 AM   #11
J Irwan
Reputation: 0 J Irwan is on a distinguished road
Samething happend to my Brother 03 M3.
Dealer replaced the whole thing without telling him.
so there goes the mirror-clear bra..
And then the new paint is falking, its hard to believe if there no way to tighten it, while looking at the diagram on realoem.com... they sell the piece that house the mirror, (not the piece that attached to the door):nixweiss:
(see #5 below)
http://www.realoem.com/bmw/showparts...33&hg=51&fg=10
Regardz,
J Irwan
02 Carbon Black ///M5
Jump to top J Irwan is offline   Reply With Quote
Old Mon, May-08-2006, 06:18:30 AM   #12
Keith_m3-4
Keith_m3-4's Avatar
Reputation: 0 Keith_m3-4 is on a distinguished road
I just noticed this on my driver side mirror as well.
Replace the entire mirror due to loose mirror sounds odd. How is the mirror secured to the housing exactly? Double sided tape?
'02 TiAG SMGII - Sold
'02 BMW 325i Touring - Sold
'06 Porsche 911S
Jump to top Keith_m3-4 is offline   Reply With Quote
Old Mon, May-08-2006, 03:08:30 PM   #13
CARBONM
Reputation: 0 CARBONM is on a distinguished road
Default mirror
I have the same problem on my 04. The dealer agreed to replace it. But they have to paint the new one so I decided not to do it yet. You all know how paint work effects future buyers of these cars. It seems to be a common problem with 04 drivers mirrors.
m
Jump to top CARBONM is offline   Reply With Quote
Old Mon, May-08-2006, 07:33:26 PM   #14
LagunaE46
Bimmerofile :)
LagunaE46's Avatar
Reputation: 0 LagunaE46 is on a distinguished road
Poland
m
i guess ill have to take it apart i got same problem , driver side is kinda loose on the mounting point ...ill keep you guys posted
Jump to top LagunaE46 is offline   Reply With Quote
Old Mon, May-08-2006, 08:29:04 PM   #15
LagunaE46
Bimmerofile :)
LagunaE46's Avatar
Poland
ok DYI: Tightening the loose mirrors
about 10 mins...open door, remove the triangle plastic that covers the mirror bolts( pry out the top of the plastic and bottom part slide up and then pull gently) once removed that unbolt the 2 10mm bolts, your mirror should be free to some out of the door, once out gently remove the rubber/foam backing there you should see 2 torx screws, if you look closely at them while moving your mirror you would notice them being loose, just tighten them up ( i just did that, but in my opinion they will be loose again, if so ill try inserting a washer there next time, i think lack of that washer and you folding/unfolding the mirror makes them loose)...voila
Old Mon, May-08-2006, 09:26:40 PM   #16
Keith_m3-4
Keith_m3-4's Avatar
Sorry, to clarify, I think it's the glass that is loose not the whole assembly.
'06 Porsche 911S
Old Mon, May-08-2006, 10:52:30 PM   #17
LagunaE46
Bimmerofile :)
LagunaE46's Avatar
Poland
i think what they mean is loose is the round plastic mirror housing( the oval piece that holds the mirror) where its mounted to the triangle piece(the piece that actually sits on the door), that whats moves, i think
Old Sat, May-13-2006, 11:46:19 PM   #18
Keith_m3-4
Keith_m3-4's Avatar
got it, the pivot is what is actually loose causing the mirror to vibrate. I tightened the 2 torx screws and feel secure now.
'06 Porsche 911S
Old Sun, Sep-23-2007, 09:06:54 AM   #19
gixxer
gixxer's Avatar
Reputation: 0 gixxer is on a distinguished road
Worked like a charm...
need2buy: LTW flywheel + clutch ;
wish: HPF ;
Mod Journal
Jump to top gixxer is offline   Reply With Quote
Old Mon, Sep-24-2007, 12:09:11 AM   #20
Str8///Left
Leave the others behind.
Str8///Left's Avatar
Reputation: 0 Str8///Left is on a distinguished road
hmm..got to do that. both of my mirrors are lose. what size torx?? is that a T25 or T30.
Jump to top Str8///Left is offline   Reply With Quote
e46, mirror, side, tighten
WTB: Passenger side Mirror M3 E46 ranchero Parts for Sale/Wanted 2 Tue, Jun-17-2008 12:51:01 AM
wtb E46 driver side mirror summy Parts for Sale/Wanted 5 Wed, Dec-20-2006 09:16:57 PM
wtb E46 driver side mirror summy Southeast 0 Tue, Dec-19-2006 08:43:20 PM
How do you remove E46 M3 side mirror glass? greg328 E46 M3 (2001-2006) 20 Sun, Dec-03-2006 12:42:16 AM
FS: E46 M3 passenger side mirror insert brettm3 Parts for Sale/Wanted 7 Fri, Nov-24-2006 05:11:34 PM
Discussing How to tighten E46 M3 side mirror? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
