Old Thu, Aug-03-2017, 03:04:39 PM   #1
Kdubski
Kdubski's Avatar
Default Differential Bushings
My bushings are starting to develop play and deciding if now is a good chance to upgrade to poly. I am a purist and prefer OEM bushings in all other regards, however, I feel as if the differential might be a place where poly may have a place (increased throttle feel).
Anyone with experience care to chime in?
Old Thu, Aug-03-2017, 03:09:38 PM   #2
Joshe46
Joshe46's Avatar
Default Re: Differential Bushings
After having 2 sets of poly, I would go Oem, unless you're doing serious track duty. They add a lot of noise when it comes to shifting, putting the car into gear, ect. Only reason I went poly is because oem is a PITA to install the front one. Theres a lot of threads that talk about the pros and cons of poly.
Jump to top Joshe46 is offline   Reply With Quote
Old Thu, Aug-03-2017, 03:39:28 PM   #3
I do feel a stronger "directness" from my pedal to the wheels since going with poly, and I appreciate it, but I don't love the NVH or slight whine at 60mph+, but I'll live.
If it's a DD, I'd stick with OE rubber.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 63mm SS V1 S pipe 63mm + 200 cell HFC OE sect 2 60mm SS Sport 60mm BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF 95a SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 376/440) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 Brembo 996 36/40 345mm Textar Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Thu, Aug-03-2017, 03:55:47 PM   #4
Kdubski
Kdubski's Avatar
What type of poly's are you guys running? Reading that there are some registering 70A on hardness scale (powerflex street), which is "slightly" harder than OEM.
Car will see some autocross once all maintenance addressed and sub frame reinforced.
Old Thu, Aug-03-2017, 04:05:42 PM   #5
Joshe46
Joshe46's Avatar
I first ran 75A revshifts which was their oem+ option. Bit mistake. The front one slipped out. I am now running AKG 95A which I know lots of guys are running.
Old Thu, Aug-03-2017, 04:09:28 PM   #6
PITT M3 RR
PA
PITT M3 RR's Avatar
ecs makes a nice 80A poly. That's just above the rubber durometer value.
I've run all 75D and it was noisy. Not like pop and rattle noisy...but there was a slight whine at highway speeds and engaging gears was all metal to metal noise...there was no give at all anymore.
I replaced the diff in the car and kept the front bushing 75D with the rear oem...that helped a lot with the nvh.
Note that I have all 95A on my e36 diff with aluminum subframe and its just as civil as before. It has a lot to do with the make up of the drivetrain. I bet if you got an aftermarket diff with better tolerances, you would not really notice a harder diff bushing. Its all how far you want to go. You cant ever go wrong with OEM.
S54 E36 BUILD
Old Thu, Aug-03-2017, 05:53:17 PM   #7
AKG 90 or 95A, can't remember.
Old Thu, Aug-03-2017, 06:47:20 PM   #8
If the car sees any street use at all, I'd stick with OE. There's very little performance benefit to aftermarket (oe is quite rigid) and tons of NHV trade off with any of the aftermarket options.
Old Thu, Aug-03-2017, 07:03:27 PM   #9
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
If you're a purist, go with OEM. If you actually care about gaining tiny bits of performance and don't mind the noise, go poly like me.
Jared's Daily/Track '02 M3 Convertible: http://www.m3forum.net/m3forum/showthread.php?t=545658
Old Thu, Aug-03-2017, 07:16:37 PM   #10
stack
The STIG
stack's Avatar
Reputation: 0 stack is on a distinguished road
Poland
I have AKG bushings black and I daily it.
This is no extra noise besides a DIFF whine which I love, and i wish it was louder.
I have some REVshift Diff bushings for sale... pm me if interested.
OEM are 75
Revshift are 80
AKG are 90/95
So it is a mild upgrade
04 E46 M3/ 95 E36 M3
Jump to top stack is offline   Reply With Quote
Discussing Differential Bushings in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
