Old Fri, Aug-04-2017, 12:44:03 PM   #11
marioec
marioec's Avatar
Reputation: 0 marioec is on a distinguished road
Default Re: Help !!! A/C is fully charged Driver side cold-passenger warm
Is there a good DIY- for the heater control valve for the e46 m3 ?
I tried doing a search and I could not find one.
2002 BMW E46 M3 / Tiag / Imola / TTFS SMG
TTFS Custom Tune
BMC Air Filter & Macht Schnell Intake Boot
STG Headers / Euro Cats / STG SCOZA Muffler
Subframe Reinforced by Active Autowerke / HSD Coilovers /Apex ARC-8 / Michelin PSS / 4.10 Motorsport Gears
Jump to top marioec is offline   Reply With Quote
Old Fri, Aug-04-2017, 12:58:33 PM   #12
Refrigerant is low. When it gets low you lose the passenger side first, then the drivers side. I don't know of anything else that causes that symptom.
BTW, the key to having your AC system not fail/leak is to use it year round. Aka, including the winter. Sadly it's too late for that, if you're leaking.
Old Fri, Aug-04-2017, 01:58:04 PM   #13
WyattH
^ I heard in addition to regular use, turn the AC off (but the leave the fans on) for a moment before you turn the car off. Truth to that? If nothing else it could dry the system out to prevent foul smells.
Old Fri, Aug-04-2017, 01:59:38 PM   #14
akagc
Reputation: 0 akagc is on a distinguished road
Obioban: Ditto on using it year round. Someone mentioned you in a youtube video with tips on the best ways to use the A/C system:
I've used that trick for the longest time: Just leave on auto and always keep the temp control knob neutral (white line in the middle) on the center vents. I adjust adjust the digital temp as needed (avg on 77), and the system automatically maintains the ambient temp comfortable with cool or heat. Been doing this for 9 years in my 330i zhp, and 3 years the m3 and both systems are still blowing cold; neither have needed recharge thus far, and I'm in FL.
One trick I also do is close the both passenger vents since I prefer to ride alone 99% of the time... it makes the flow of air stronger on the driver vents.
Tip: I've seen cases where if the blower motor is on it's way out, it will make a bird type chirping sound while the system is in use, and this will be audible in the cabin.
- 04 Silver (tiag) ZHP 330i
- 06 Silver Grey ZCP M3
- 02 Black Civic. Beater
Jump to top akagc is offline   Reply With Quote
Old Fri, Aug-04-2017, 02:31:20 PM   #15
Originally Posted by akagc View Post
Obioban: Ditto on using it year round. Someone mentioned you in a youtube video with tips on the best ways to use the A/C system: E46 M3 Tips and Tricks Vol. 2: Auto Climate Control - YouTube
That's because of this thread I made a while back, when I realized everyone was trying to use their automatic climate control as manual climate control:
http://www.m3forum.net/m3forum/showthread.php?t=427235
Discussing Help !!! A/C is fully charged Driver side cold-passenger warm in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
