Old Tue, Aug-01-2017, 06:27:37 PM   #1
sooch
Reputation: 0 sooch is on a distinguished road
Default Hot Start Issues
Hey Guys,
Past 2-3 weeks I have been experiencing a strange issue.... My day typically unfolds like so:
Early morning start - flawless
Drive 20-30 minutes to work - flawless
Come back out for lunch at noon- 50% chance it doesn't turn over
-The radio works, the lights work, just no noise - no starter nothing
-Turn the key 4-5 even 10 times it will finally turn over.
Drive to and from work- 50% chance it turns back on on first turn after a short drive.
Jump in car, while in shade after work- 75% chance it turns over on first go.
Drive home 20-30 minutes- flawless
If parked in the shade it is typically a non-factor, but even after short drives and parked to sit for 20-30 minutes it will act up. So what could be the cause of this? I have no codes, no lights, NADA and only seems to happen in the heat. My Key FOBs both have started losing distance to unlock so that may be the problem? I don't feel like throwing $200 at a key fob to find out it was fine all along....
Jump to top sooch is online now   Reply With Quote
Old Tue, Aug-01-2017, 06:48:28 PM   #2
HassanEido
HassanEido's Avatar
Lebanon
Default Re: Hot Start Issues
Starter
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box pending
357.7 whp 283.5 wtq
Old Tue, Aug-01-2017, 09:15:57 PM   #3
sooch
Starter
The starter isn't making any noises whatsoever.... Which leads me to believe it is an electrical issue? Is this something you've experienced?
Old Tue, Aug-01-2017, 10:44:00 PM   #4
HassanEido
HassanEido's Avatar
Lebanon
Yes. Its basically the starter solinoid. Gets old and tolerances become out of spec when hot. When cold all was well. It started to gradually get worse, got a new starter and back to busines
Mods:
357.7 whp 283.5 wtq
Old Tue, Aug-01-2017, 10:51:22 PM   #5
Kontiki
Reputation: 0 Kontiki is on a distinguished road
I'm experiencing this as well. I've read several threads and they all point to replacing the starter as the solution. Ordering mine from ECS now.
Jump to top Kontiki is offline   Reply With Quote
Old Wed, Aug-02-2017, 01:50:59 PM   #6
sooch
It looks like I will be grabbing one from FCP Euro for $179 - Bosch Unit. $100 core charge. Lifetime warranty.
Reading up on DIYs as we speak, it looks hard but the DIY's say its easy....
**Thanks Hassan!!**
Old Wed, Aug-02-2017, 04:43:36 PM   #7
Mrmiller
Reputation: 0 Mrmiller is on a distinguished road
I had a similar situation whenever it's cold the car doesn't turn. I thought something with the fuel because the starter doesn't make any clicking noise. The other night it took a second extra to start. So I guess I will change the starter soon
Jump to top Mrmiller is offline   Reply With Quote
Discussing Hot Start Issues in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
