Old Mon, Jul-31-2017, 02:37:23 AM   #1
IMPULSEgravy
Reputation: 0 IMPULSEgravy is on a distinguished road
Default empty threaded hole source of oil leak?
I was getting under the car to change my rod bearings (I have a knock) and when I pulled off the plastic skid plate thing I was surprised by a massive oil leak. The source seems to be this empty threaded hole (pictured). I have no idea what is supposed to be here. I'm really just learning how to work on my car so any advice is appreciated
Picture: https://1drv.ms/i/s!Apf_nYiqApxtqz7-RfrFbhYN8LJV
Jump to top IMPULSEgravy is offline   Reply With Quote
Old Mon, Jul-31-2017, 04:06:52 AM   #2
Drewster
Drewster's Avatar
Default Re: empty threaded hole source of oil leak?
Doubtful - probably your CPV O-Ring.. very common
Old Mon, Jul-31-2017, 04:08:17 AM   #3
bimmerfan08
bimmerfan08's Avatar
That's a lot of oil and given that your PS line is caked in it, it could be the high pressure VANOS line that threads into the accumulator in the pic.
How bad is the knock you speak of? How many miles on the engine?
Old Mon, Jul-31-2017, 05:32:02 AM   #4
IMPULSEgravy
Sway bar and ps lines were both caked and dripping. The engine has 147kms on it and the knock had just started a block away from home and was pretty bad. I posted about it a few days ago with a video link (here it is:
Discussing empty threaded hole source of oil leak? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
