Old Sat, Jul-29-2017, 06:25:09 AM   #21
silvergray545
silvergray545's Avatar
Default Re: Best Value vs. Performance Radiator for Track Duty 2017?
I recently installed a CSF radiator. I must say, the fitment was spot on. Some of the radiators mentioned above require some modification to fit properly (or so I've heard). Was really impressed that the CSF dropped right into place.
2004 BMW M3 6MT - TiAg/Gray
2016 BMW M3 ZCP 6MT - AW/SO
2014 VW GLI 6MT - Black/Black
Instagram
E46 M3 Build Journal
Old Sat, Jul-29-2017, 07:00:40 AM   #22
bjz
bjz's Avatar
Reputation: 0 bjz is on a distinguished road
Spain
BW Radiators = PWR. Top of the line with Zionsville.
Jump to top bjz is offline   Reply With Quote
Old Fri, Aug-04-2017, 01:46:15 AM   #23
speeeding
Reputation: 0 speeeding is on a distinguished road
Originally Posted by lmtfi View Post
Yes - I've never been off the dead middle in either car (until the 2nd went high at the sustained top end on the dyno - but that car is new to me).
Consider shifting to 100% water + WW - and then changing back at the end of track season.
Some people have been using NanoPro MT's "NanoCool" with water.
Does NanoCool perform better than WW?
Jump to top speeeding is offline   Reply With Quote
Old Fri, Aug-04-2017, 02:15:24 AM   #24
lmtfi
lmtfi's Avatar
Although strongly endorsed in some track circles - I haven't seen data on it. There is a guy that says he is going to do a same-car comparison and report temp info he collects.
I think one needs to first move to 100% distilled water first (off 50/50 coolant). Then see what temperature results for you in your car/radiator in your track temps.
I'd say that if all water doesn't fix the problem - the difference between WW and Nano aren't going to fix what ails the cooling system.
Old Fri, Aug-04-2017, 03:54:01 AM   #25
speeeding
I wouldn't be against using 100% distilled water, and freezing isn't an issue for me here in CA. However my indy tech told me the BMW coolant is also an anti-corrosive. I wonder if that's really true.
Old Fri, Aug-04-2017, 04:06:25 AM   #26
It is true, so run 10% or something. Don't the wetter water and other surfactants also have anti-corrosive properties too?
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 63mm SS V1 S pipe 63mm + 200 cell HFC OE sect 2 60mm SS Sport 60mm BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF 95a SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 376/440) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 Brembo 996 36/40 345mm Textar Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Wed, Apr-04-2018, 10:51:35 PM   #27
androofoo
Buildjournal
androofoo's Avatar
Reputation: 0 androofoo is on a distinguished road
How many people actually have had the OEM radiators crack at the plastic end tanks?
2003 BMW AW/Cinnamon E46 M3 6MT | B-Spec Tune
2012 BMW Sapphire Black/Black F30 328i | GIAC Stage 1 Tune
Follow this build on thebuildjournal.com
Jump to top androofoo is offline   Reply With Quote
Old Wed, Apr-04-2018, 11:47:14 PM   #28
makjur
Reputation: 0 makjur is on a distinguished road
I want to know this as well.. I'm at 123k and am thinking about replacing mine with another OEM. But I'm reluctant to spend the money since everything seems fine.
Sent from my SM-G960U using Tapatalk
Jump to top makjur is offline   Reply With Quote
Old Thu, Apr-05-2018, 12:16:56 AM   #29
stash1
To be fair, I haven't seen issues with Mishi after their design update
Originally Posted by mdavidm3 View Post
I'm running the newer mishimoto rad with no issues
Running the newer design Mishi as well...also w/no issues and install was pretty much factory like. I wanna try the Koyo rad just becuz, but hear it requires a trip to the hardware store as it doesn't reuse the factory bolts...unless there's been a recent update?
'04 AW/IR...Not Stock
Old Thu, Apr-05-2018, 12:39:32 AM   #30
lmtfi
lmtfi's Avatar
http://www.redlineoil.com/content/fi...ech%20Info.pdf
Discussing Best Value vs. Performance Radiator for Track Duty 2017? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
