Old Thu, Jul-27-2017, 03:52:35 PM   #21
ModBargains.com
ModBargains.com's Avatar
Reputation: 0 ModBargains.com is on a distinguished road
Default Re: I can't believe what these weigh - Sportline 8S - CSL Style wheel Content
Optimal sizes for the E46 M3
Squared
18x8.5 ET32 all around
19x8.5 ET35 all around
Staggered
18x8.5 ET32 front
18x9.5 ET22 rear
19x8.5 ET35 front
19x9.5 ET22 or 19x10 ET20 rear
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | KW Coilovers |
AE Performance | Remus Exhaust | BMW Performance Exhaust
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm (PST)
Check out the Blog! or add me on Facebook! for daily updates and discounts!
Jump to top ModBargains.com is offline   Reply With Quote
Old Thu, Jul-27-2017, 04:13:36 PM   #22
The optimal squared set would be 9.5" not 8.5", for this car, not nonM e46s or e36 m3s. You should not be running a 8.5" in the rear, esp if tracking and you shouldn't be going square really unless tracking.
Given that all other reps (and stock wheels) are mid-20 lbs or more, a 21 lb one is great, notwithstanding Obioban's odd statement.
Leave it to Ian, a moderator, to attack the product of a forum sponser
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 63mm SS V1 S pipe 63mm + 200 cell HFC OE sect 2 60mm SS Sport 60mm BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF 95a SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 376/440) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 Brembo 996 36/40 345mm Textar Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Thu, Jul-27-2017, 04:23:49 PM   #23
ModBargains.com
Fitments described are direct bolt on without any work required which is what the majority of guys will run for the street. For the smaller % of guys going on for a stance look or track purposes, the 18x9.5 ET22 or 19x9.5 ET22 can work up front. Definitely no clearance issues out back. However, it would be considered semi aggressive up front & will require negative camber up front to have the proper fender to tire clearance.
Assuming this is a street car running street tires, you will need approximately -2.6 to -3 degrees of camber up front to achieve enough tire to fender clearance for 265/35/18's. 275/35/18's street tires will require approximately -3 to -3.5 degrees of negative camber up front. This is a bit aggressive for a street car and is not typically recommended.
Hope that helps to clarify a few things!
Old Thu, Jul-27-2017, 04:51:16 PM   #24
poms302
Reputation: 0 poms302 is on a distinguished road
Any plans for 17x9.5 with 22et and 35et? If these came in under 17 pounds like Arc8 I would buy.
Jump to top poms302 is offline   Reply With Quote
Old Thu, Jul-27-2017, 04:57:13 PM   #25
ModBargains.com
There are currently no plans to bring these in 17"
Old Thu, Jul-27-2017, 06:28:38 PM   #26
Ph03nix46
Reputation: 0 Ph03nix46 is on a distinguished road
Chyea. See my sig.
Jump to top Ph03nix46 is offline   Reply With Quote
Old Thu, Jul-27-2017, 06:32:11 PM   #27
ModBargains.com
Originally Posted by Ph03nix46 View Post
Chyea. See my sig.
Old Thu, Jul-27-2017, 07:31:35 PM   #28
Brian N
wubalubadubdub
Brian N's Avatar
It is a good looking wheel. I just wish that: it was offered in more sizes (18x9.5 et 28-35 and a 18x10 size maybe), it was a little lighter weight (seems like the spokes are a tiny bit thick), and that the concave rear fitments looked like the genuine ZCP/CSL without the kink in the spoke. The second two are just nitpicking if I'm honest but would be nice.
-My Journal-
Old Thu, Jul-27-2017, 07:36:09 PM   #29
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
yea that's what i thought. but not everyone uses spacers and actually prefer the oem specs.
Originally Posted by ModBargains.com View Post
Factory offsets are a bit more conservative. Most would probably run spacers to push them out and make them just a tad more flush with those fitments.
Sportline as well as many other wheel companies take that into consideration and build the wheels to be slightly more aggressive to achieve a flush look without the need to use spacers.
Tischer aka GetBmwParts
Old Thu, Jul-27-2017, 07:47:01 PM   #30
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Isle of Man
Are you requesting that moderators push sponsor products on you as opposed to having independent thought?
Andrew
Current - '05 Interlagos E46 M3 SMG Delete 6MT Coupe - 3350lbs
911 Journal/Build Thread
No fun no care
Discussing I can't believe what these weigh - Sportline 8S - CSL Style wheel Content in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
