Old Mon, Jul-10-2017, 08:01:31 PM   #21
E46_USMC
E46_USMC's Avatar
Reputation: 0 E46_USMC is on a distinguished road
Default Re: I attempted a M3 Swap and failed
Dude the hard part is over! I bet its something so stupid, you're going to kick yourself for overlooking it.
You must not be married. I know this because she would have killed you before you had the chance to post this.
Jump to top E46_USMC is offline   Reply With Quote
Old Mon, Jul-10-2017, 09:10:06 PM   #22
Jaap
Reputation: 0 Jaap is on a distinguished road
Did you replace the DME or reprogram it?
Is your VIN written correctly on all units that need it (DME, EWS, DSC if i remember correctly)?
Do you have access to INPA or DIS?
Jump to top Jaap is offline   Reply With Quote
Old Mon, Jul-10-2017, 09:37:09 PM   #23
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
this thread makes zero cents, costed way too much of my time so I had to post
Topo Chico
Old Mon, Jul-10-2017, 10:00:59 PM   #24
ThunderMoose
Originally Posted by NickSM View Post
I realize that the car is "supposed" to still start before reprogramming the software (to tell the car it's now a manual not an SMG) but could that be part of the problem? I didn't see any mention of reprogramming in your post.
I have never reprogrammed mine and it runs to redline. If you don't program it, the SMG ECU needs to be connected to the DME to get past limp mode but it will start and run even with SMG computer removed.
Literally, you need 1 wire to EWS to make the car start without programming.
#67 2017 NASA TX TT3 Champion
Old Mon, Jul-10-2017, 10:18:52 PM   #25
ThunderMoose
My SMG knowledge is near 0 (neither car has it), but SMG cars I've driven won't turn on if the hood is open...?
They are definitely finicky. I could be mis remembering but easy for OP to test. I am interested to know if he's pushing in clutch when he tries to start. Also to learn how he powered the clutch switch. The guide has you tapping into brake switch but I ran a separate feed from the fuse box.
Old Mon, Jul-10-2017, 11:14:28 PM   #26
Dave B
M3 collector
Dave B's Avatar
Italy
Yeah, if it doesn't even turn over once it seems to me like maybe the switch isn't working properly. Even mis-wired, the thing ought to start otherwise.
As for SMGs, it should start but not allow you to put it in gear if the hood is open. At least that's how mine is. Hood switches can be finicky, though, from what I know of them.
Old Tue, Jul-11-2017, 12:24:33 AM   #27
ajb211
ajb211's Avatar
Reputation: 0 ajb211 is on a distinguished road
Stupid question but are you pushing in clutch when you try to start?
Also do you have access to INPA to see if clutch switch is activating.
Lol yes to the first one.
but actually no to the 2nd
Jump to top ajb211 is offline   Reply With Quote
Old Tue, Jul-11-2017, 12:26:05 AM   #28
ajb211
ajb211's Avatar
Hey i am pushing in the clutch when i try to start it.
and here is how i wired the car
http://www.m3forum.net/m3forum/showthread.php?t=546749
Old Tue, Jul-11-2017, 12:27:50 AM   #29
ajb211
ajb211's Avatar
that's correct i did not touch the computer in the car yet. but i am under the impression that i should be able to start it without any programming. could that be the issue?
Old Tue, Jul-11-2017, 12:31:05 AM   #30
ajb211
ajb211's Avatar
Are you saying i should check if the VIN matches on all of those components? if so i will check.
Also i do not have access to INPA or DIS. The original plan was to limp mode drive it to a shop and have them do the programming.
Discussing I attempted a M3 Swap and succeeded! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
