Old Tue, Dec-27-2011, 04:07:45 AM   #11
Vonbimmer
Reputation: 0 Vonbimmer is on a distinguished road
Default Re: P0420 Question and Introduction
One other quick question, I noticed they are numbered on the leads does that notate the bank they are supposed to be in?
Thanks again I've searched quite a bit for this info
2001 M3 TiAg on BLK, 6 Spd Man, ZCP's, Koni's, RE RSM's, H&R springs, Hotchkis sways, Custom Performance headers, SS Race cats, SG sec 2, Evolve-R tune, Afe elbow, RPI scoops, BMC Filter, FS IAT Relocation, VAC Underdrive Pulleys, Mishimoto fan kit
Jump to top Vonbimmer is online now   Reply With Quote
Old Tue, Dec-27-2011, 05:07:04 AM   #12
MattMan
Modded
MattMan's Avatar
Reputation: 573 MattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond repute
Originally Posted by Vonbimmer View Post
Thanks Mattman! I'll pull the plastic off the valve cover and check things out, btw, what do the "key" notations mean?
Key refers to connector face type or layout.
MattMan
2013 IB E92 M3 6MT
IG: @mattzcp
Jump to top MattMan is offline   Reply With Quote
Old Tue, Dec-27-2011, 11:26:00 PM   #13
Vonbimmer
Exclamation Re: P0420 Question and Introduction
Ok, I think the holidays killed some brain cells. Mattman, can you do me a favor and look at these pics. These are the two 02 sensor connections that are currently in the pre-cat position. I just wanted to get a second opinion. Plus since two are style Key=A how do I not mix them up?
Sorry tried to embed the image,but no dice.
Old Wed, Dec-28-2011, 03:29:15 AM   #14
MattMan
Modded
MattMan's Avatar
https://skydrive.live.com/redir.aspx...6807E72455!516
Hi Charles,
Those actually look like post-cat sensors (at least the bottom one).
The 2 sensors that are way back on the valve cover towards the firewall are the pre-cats.
The tricky part is that the face or KEY for precat bank 2 is the same as post cat bank 1.
In your pic, it is clear that the BOTTOM sensor is the Post cat bank 2 face (look closely at the key shape compared to the diagram I posted). If you traced to wire to the top of the valve cover you will probably see that one connected to the O2/EGT wire loom and not the connector holders towards the back.
The top one may be correct.. but I would trace the wire route as well to make sure it's going to the right place (per the diagram posted).
P.S. I fixed the image so it's visible in your post..
MattMan
2013 IB E92 M3 6MT
IG: @mattzcp
Old Wed, Dec-28-2011, 04:14:15 AM   #15
Vonbimmer
Thanks for the additional info, I'll trace those back and see but since it's been apart and the wiring holder is off it may be tough to tell. If I unplug one will it throw a code identifying it?
Old Wed, Dec-28-2011, 06:53:03 PM   #16
Vonbimmer
Well I think I'm good to go, I disconnected one of each of what are currently my bank 1&2 pre cat O2's and the idled the car until I got an error for each. Got errors for bank 1 sensor 1 and bank 2 sensor 1, they seems to match locations so I think I'm good to go
Old Wed, Dec-28-2011, 09:55:11 PM   #17
Vonbimmer
Just cleared all the codes and drove the car, all readiness areas passed. Of course it's an unseasonal 61F instead of what had been 10F with a high of 34F. Thanks to,everyone for the helpful feedback! I'm excited to be in the e46 community. I'll post a picture of the car as soon as I get a chance.
Old Wed, Mar-07-2012, 06:14:35 PM   #18
Mr. Vapor
Mr. Vapor's Avatar
Reputation: 0 Mr. Vapor is on a distinguished road
subscribed in case i need this info (though i hope i nail it right the first time!)
2006 M3 - Competition Package - Carbon black [Nav] [M-DSC] [HK] [ZPP] [ZCP]
[Evolve-R] [Supersprint Race] [Evosport SS headers] [CPI Euro200R] [Powerflex RTABs] [RE RSMs] [FK Silverline Plus X coilovers] [AFE Intake Arm] [Black kidneys/grilles] [Smoked corner lights] [Powdercoated 19" CSL ] [235/265 CSL spec Potenza Pole Positions] [Smoked reflectors] [30% tint] [Iconz CF 1-piece race lip] [RPI Scoops]
Jump to top Mr. Vapor is offline   Reply With Quote
Old Mon, Jul-31-2017, 09:44:32 AM   #19
El Segundo
Reputation: 0 El Segundo is on a distinguished road
Old post I know but does anybody have the image posted by MattMan? It seems I have a very similar issue.
Jump to top El Segundo is offline   Reply With Quote
Discussing P0420 Question and Introduction in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
