Old Thu, Nov-18-2010, 08:32:39 PM   #1
peppermdx
Reputation: 0 peppermdx is on a distinguished road
Default 06 vert 6 speed shifting problems
I had the car since new, recently had inspection 2 done with over 45k mostly trouble free miles. Recently, I am having problem shifting into reverse, and notice the problem to be more common when the car sits on uneven ground. IE, gravel road, or roads with pot holes. Called the dealer, and they thought this was common issue among 6 speeds. They suggested that I shift into first, then into reverse. I never had any issues until now, hoping someone on this board can shed some light. Oh, any good shops I can take it to in Beaverton OR? Thanks in advance.
Jump to top peppermdx is offline   Reply With Quote
Old Thu, Nov-18-2010, 08:33:43 PM   #2
PerkM3
PerkM3's Avatar
Reputation: 0 PerkM3 is on a distinguished road
Post in the e46 section, you will get more help there.
Jump to top PerkM3 is offline   Reply With Quote
Old Fri, Nov-19-2010, 01:29:24 AM   #3
elp_jc
Reputation: 0 elp_jc is on a distinguished road
WRONG FORUM buddy, but yes, you should do that on any manual car. On my M3 I actually have to row to 1st and 2nd before R. It's the most reluctant tranny to go into R I've ever owned. Plus the spring is ultra stiff. If it started doing that just recently, might be an indication you need to change the oil. When was the last time you did that? I'd start there. Good luck.
'08 E92 M3, Silverstone/Black Extended (w/carbon leather), 6MT
Premium/Tech/Cold packages, Ext. Leather, 19s, Pwr Sunshade, Park Dist., iPod/USB, HD radio, Sat Radio, Enhanced Premium Sound, Moonroof.
MODS: P/C black 19s, BMW perf. grilles, body-colored gills, black stock exhaust, reflector delete, euro light switch, alum pedals, ZHP lighted knob, tint.
Jump to top elp_jc is offline   Reply With Quote
problems, shifting, speed, vert
Discussing 06 vert 6 speed shifting problems in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
