Old Fri, Sep-17-2010, 05:51:15 PM   #1
Aduras
Reputation: 0 Aduras is on a distinguished road
Default 0-100 in 4.6?? Anyone able to achieve this??
I have an 08 M3 with the dinan engine software upgrade and the OEM Performance Steering wheel. Using the steering wheel, it can accurately time my 0-100 km times. However, in numerous numerous tries, fastest I've been able to get is 5.4 seconds. I'm no where close!
So I went online and tried to find videos to improve my launch but in all the videos I've seen, they are all well above the 5 second mark too.
Can anyone share their experience with their launching?
Jump to top Aduras is offline   Reply With Quote
Old Fri, Sep-17-2010, 06:00:50 PM   #2
Aduras
I've had many mechanical issues with my car, so I'm worried my engine could be malfunctioning and not producing as much power as it should be for whatever reason.
Should I be in M-DCT mode, or have the DCT completely off?
Old Fri, Sep-17-2010, 06:04:11 PM   #3
Z@T
Pilot
Z@T's Avatar
Reputation: 0 Z@T is on a distinguished road
Germany
Yes. DTC complete off.
Otherwise you'll never hit the 5 seconds.
Tobi
Life's too short to drive boring cars
Jump to top Z@T is offline   Reply With Quote
Old Tue, Sep-21-2010, 08:18:10 PM   #4
Drei28
Drei28's Avatar
Reputation: 0 Drei28 is on a distinguished road
Guys, instead of giving your 2 cents on something the OP NEVER asked such as "these cars aren't meant to... don't drag race...0-60 doesn't mean anything... I'm from the motorcycle world... etc". Try to answer the question at hand; what does the OP have to do to reach his target 4.6 sec 0-100km.
If you check out Tiff's review of the M3 (around the 2:00 min mark) he does a couple of launches in different settings w/ the DCT - and he points out the fastest launch. Hope this helps
http://www.youtube.com/watch?v=YODPHqY7mM4]width=560
Jump to top Drei28 is offline   Reply With Quote
Old Tue, Sep-21-2010, 11:29:03 PM   #5
MMC2488
MMC2488's Avatar
Reputation: 0 MMC2488 is on a distinguished road
Just curious. Are your power settings set to 11?
Jump to top MMC2488 is offline   Reply With Quote
Old Tue, Sep-28-2010, 01:13:03 AM   #6
SilvertM3
SilvertM3's Avatar
Reputation: 0 SilvertM3 is on a distinguished road
"DCT off?" Shut the dual clutch off? Don't you mean shut off the DCP???
2009 M3 Convertible-Silverstone Metallic II on Black w/Novillo & Carbon Fiber Int, DCT, Tech/Premium pkg, Nav, 19s, Rear lip spoiler, Invisi-Bra, Lo-Jack Security.
Jump to top SilvertM3 is offline   Reply With Quote
Old Tue, Sep-28-2010, 01:26:24 AM   #7
patty
Reputation: 0 patty will become famous soon enough
No, I think he means DSC.
2016 Porsche Cayman GT4 -Voodoo Blue
Jump to top patty is offline   Reply With Quote
Old Wed, Sep-29-2010, 07:22:11 PM   #8
Malibu101481
Malibu101481's Avatar
Reputation: 0 Malibu101481 is on a distinguished road
'08 Blk/Blk DCT Coupe
Traded '08 Range Rover Sport HSE
Turned in '07 335 Coupe
Sold '01 M3 Coupe
Jump to top Malibu101481 is offline   Reply With Quote
Old Wed, Sep-29-2010, 09:11:01 PM   #9
mmihld
////// Horny M3 Owner //////
mmihld's Avatar
Reputation: 0 mmihld has disabled reputation
Follow this procedure to achieve the best possible 0-60 time:
a. Turn off all accessories (e.g. A/C, Radio, Waffle Iron, etc.).
b. Ensure you only have the minimum amount of gas in the tank (weight = time).
c. Remove all aftermarket accessories like painted reflectors, those suckers add about 10mg of weight to the car.
d. Use the restroom prior to attempting your speed run. Evacuate all bodily fluids and solids.
e. Kick out any passengers.
f. Remove the cigarette lighter, that's another 70mg of weight right there.
g. Empty your pockets. God knows what you have in there, which could be another pound or two.
h. Check the trunk for dead bodies or any other non essentials. Remove as needed.
I. Close all windows, sunroofs, the trunk and the hood.
j. Wash your car immediately before attempting your run. Be sure to remove all the dead bees from the A/C condenser (good for 20-60mg of weight)
k. Pack the drag cute and verify the opening mechanism
l. Check the wheelie bar
m. Remove the front wheels and install schwinn 10-speed wheels (this is great for a reduction of weight and friction)
n. Do multiple burn-outs to get the rear tires nice and warm. You know when you have reached the tire's optimal temperature when you can visibly see the rubber melting
o. Point the car down a long and steep hill
p. Rev motor, dump the clutch and off you go!
This should be good for a 0-60 time of around 4 seconds, depending on the steepness of the hill.
After your speed run, immediately turn on your waffle iron. There is nothing worse than having cold waffles after a hard workout....
2014 Banana Yellow 1 cylinder turbo charged M3 / Black Interior
Jump to top mmihld is offline   Reply With Quote
Old Fri, Oct-01-2010, 09:37:35 PM   #10
ns21
ns21's Avatar
Reputation: 0 ns21 is on a distinguished road
Hm.... 5.4 sec it looks funny to me. I got on my stock 10.2003 E46 M3 coupe SMG a 5.13 sec on asphalt and 4.55 sec on concrete with no special preparations, just the DSC off and a decent launch control ... I would have bet that the E 92 is capable of 4.7 manual and 4.5 DKG on asphalt and close to 4 on better surface ...
Jump to top ns21 is offline   Reply With Quote
achieve
Discussing 0-100 in 4.6?? Anyone able to achieve this?? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
