Mobile M3forum |
E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#1 |
![]() Location: Henderson
So It is very possible that I over tightened the input flange nut! I heared a whiz . Just yesterday I took it for an alignment and after I left it got pretty bad. The guys at the shop showed me some play at the input flange!
After I left the shop, I could hear a strong sound from the diff , especially when I am decelerating (either by using the brakes or just letting it cruise to a stop). So the question is 1. is this a sign that the pinion is toast ! 2. if that is indeed the case, am I just better off getting another diff (heck, maybe it's a sign from the heavens it's time for a 4.10) To be clear, I want this fixed without spending unneeded extra cash. Having said that, if I am going to blow above +$1000 , then I'll start considering a diff upgrade. Thanks,
2002 Titanium Silver BMW 325Ci SOLD 2003 Estoril Blue BMW M3 2003 Estoril Blue BMW M3 Journal How to Import a car from Canada Last edited by TheCoder; Wed, Feb-15-2017 at 03:42:49 PM. |
Sponsored Links |
#2 |
Banned
![]() Location: Wicked Witch Of The West’s House
idk man. Where'd you go for the alignment?
I feel SWB or Sin City you're 500+ anyway looking at it. |
#3 | |
![]() Quote:
Sent from my SM-G930P using Tapatalk
2002 Titanium Silver BMW 325Ci SOLD 2003 Estoril Blue BMW M3 2003 Estoril Blue BMW M3 Journal How to Import a car from Canada |
#4 |
What's your mileage? It might just be time for a rebuild.
#5 |
Its only 99k. What is normally the "time to rebuild" ? I dont think its 99k...
#6 |
I think fast, I talk fast and I drive fast...
When I had diff issues I did a ton of research and found that people experience with getting the diff rebuilt at local shops varied WIDELY. I ended up ordering a new diff through Turner Motorsports who gets them directly from Dan at diffsonline. Dan is arguably the most knowledgeable guy out there on BMW diffs and can customize them any way you want. My new diff with upgraded REM polished 3.91 gears and replaced the Mvariable LSD with a traditional 3 clutch pack was pricey but I've had zero issues. You are paying for peace of mind. If you want a rebuilt stock unit it will be less expensive of course. Sometimes it pays to make a larger investment to get it done properly at a shop with a known reputation. Sorry to hear you are having so many issues. Just my 2 cents...
2005 BMW M3 ZCP - Black/Black Built not bought. All DIY! Evolve-R | AP V2 Headers | CPI Euro200R (200 cell) | SS Non-res X-pipe + Race | 3.91 w/ 3 stage clutch | TCK SA 450/500 | Vorshlag Camber Plates Rogue Engineering ASP, RSM, RTABs, TM | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | aFe Stage 2 | SPAL Fan AKG FCABs, SFB | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings |
#7 | |
![]() Quote:
I didnt do anything yet, but im preparing for the worst. However, just like your case, I'm taking this as a sign from the heavens that i need a 4.1 ( or 3.91). Let me inspect the diff first, but if i end up needing a replacement, then i might just upgrade. Sent from my SM-G930P using Tapatalk
#8 |
![]() Location: Oklahoma City
If you under tightened it, you may be able to tighten it back up - you did mark the position of the pinion nut before you loosened it, right? The idea is to put the nut back on to the same relative position as it was originally - it's not torqued to a specific torque spec. If you didn't mark the nut before removal, this will be a crap-shoot at best.
If it's over tightened, you've over-crushed the crush sleeve and you're totally screwed. There's no fixing it besides pulling the diff and completely disassembling it, replacing the crush sleeve (and anything else worth replacing while you're at it). In either case, there's a high probability it's time for a rebuilt diff. Good Luck!
-Darrell 2001 M5 Jet Black / Black |
#9 | |
![]() Quote:
Anyway, I am shopping around and I came across a 4.1 diff by Fall-Line motor sports for a decent price. Are they a reputable shop when it comes to diff rebuilding ?
#10 |
![]() Location: Bellevue, WA
Hey TheCoder! Sorry to hear that happened. Just curious, what were you doing on your diff?
2003.5 E46M 6MT ![]() |
Bookmarks |
Thread Tools | |
Display Modes | |
