Old Fri, May-17-2019, 06:54:41 PM   #1
drunkuncas
Reputation: 0 drunkuncas is on a distinguished road
Default Replaced my fuel pump. Fires, won't run. Pumping fine.
FU to http://www.m3forum.net/m3forum/showthread.php?t=607429
Pump primes, then squirts when cranking into a bucket.
Car fires once, then dies- exactly like it did before pump replacement.
Relay bench tested. No current codes, but my TPS has occasionally been giving me an EML when I punch it in a higher gear.
Ground on passenger side engine good.
Ideas?
Solved: Check your MAP
Jump to top drunkuncas is offline   Reply With Quote
Old Fri, May-17-2019, 08:41:02 PM   #2
Texaz3
Default Re: Replaced my fuel pump. Fires, won't run. Pumping fine.
If the car does exactly what it was doing before the pump replacement, why did you think it was the pump?
“Aerodynamics are for people who can't build engines.” - Enzo Ferrari
Old Fri, May-17-2019, 08:41:29 PM   #3
Resync your EWS.
Old Fri, May-17-2019, 09:14:24 PM   #4
drunkuncas
Because the pump was only running when jumped. And the 119k miles.
Old Fri, May-17-2019, 11:15:02 PM   #5
drunkuncas
Works with the MAF unplugged.
Old Fri, May-17-2019, 11:28:05 PM   #6
eacmen
Try cleaning the MAF. You might find that fixes the issue for a few weeks/months.
If cleaning doesn't work get new MAF. I would get it from FCP in case it dies again you'll get a free replacement.
Jump to top eacmen is online now   Reply With Quote
Old Fri, May-17-2019, 11:58:21 PM   #7
drunkuncas
Damn. And $75 less than ECS
Old Sat, May-18-2019, 12:54:15 AM   #8
nowanker
"He's no wanker!"
Reputation: 0 nowanker is on a distinguished road
It's fun to imagine that all automotive techs are theivin', lyin', ignorant pieces of sh*t.
But sometimes.... It's cheaper to pay one of us to actually diagnose the problem for you.
Sorry for the rant, and sorry for your misfortune. Hope you can hit on the problem without too many more misses.
Jump to top nowanker is offline   Reply With Quote
Old Sat, May-18-2019, 02:47:59 AM   #9
drunkuncas
I guess you missed the part where I stated that the original pump wasn't turning on with the car, but would only pump when jumped. No prime. No squirt when cranked. Nothing.
I'm in a bay between a guy who builds race cars, and a guy who wrenches at a high end German repair shop. Can you guess which one didn't know how to bench test a relay, and suggested my solution lay in buying parts to swap out?
Old Sat, May-18-2019, 02:23:17 PM   #10
nowanker
"He's no wanker!"
Not all techs are idiots, but not everyone who works in a repair shop knows how to think. If someone displays their diagnostic ignorance... maybe not the best source of advice?
Sometimes it is the best diagnostic strategy just to swap parts. Some components defy testing, or have intermittant failures that are hard to catch. Or they're know failure items that you might want to change anyway.
When that strategy is the only one a 'mechanic' knows... run away.
Good luck, let us know what you find!
Discussing Replaced my fuel pump. Fires, won't run. Pumping fine. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
