Old Wed, Aug-01-2012, 01:08:18 AM   #1
sharde26
Reputation: 0 sharde26 is on a distinguished road
Question Continuing Brake Trouble
Hi all,
I wouldn't ask if I wasn't at a loss. My front driver's side brake caliper keeps on dragging. I have replaced the caliper....twice, and replaced the hydraulic line. As far as I know I have only the metal line and the brake master cylinder left to replace. Can anyone give me a heading as to which it might be?
The strangeness of the thing is that whenever I bleed the brakes, I have no trouble for months. It is almost like air is seeping into the lines over time. Only on the front driver's side though.
Any thoughts?
Jump to top sharde26 is offline   Reply With Quote
Old Wed, Aug-01-2012, 01:13:19 AM   #2
aeronaut
aeronaut's Avatar
Reputation: 0 aeronaut is on a distinguished road
Default Re: Continuing Brake Trouble
Interesting. How do you know it's dragging?
Jump to top aeronaut is offline   Reply With Quote
Old Wed, Aug-01-2012, 01:18:38 AM   #3
sharde26
Another note, it only seems to start happening after driving for awhile above 60 mph. At that point the steering wheel start shaking and the car starts pulling slightly to the left. Also the heat coming from that wheel afterwards is a dead giveaway. The caliper is very hot to the touch.
Old Wed, Aug-01-2012, 01:22:47 AM   #4
aeronaut
aeronaut's Avatar
Well, I'm at a loss. I'm sure others will have ideas. Have you checked rotor runout?
Old Wed, Aug-01-2012, 01:25:49 AM   #5
sharde26
I have not. I'm inclined to think that a warped rotor isn't the problem though. This all started last year when my caliper seized up.
Old Wed, Aug-01-2012, 01:35:17 AM   #6
aeronaut
aeronaut's Avatar
I wouldn't think so either, but was just thinking of easy things to rule out.
Old Wed, Aug-01-2012, 01:38:22 AM   #7
sharde26
Makes sense. I work in IT and my first question is always "Is it plugged in?"
Old Wed, Aug-01-2012, 04:09:36 AM   #8
enderw88
Rolling Restorer
enderw88's Avatar
Reputation: 0 enderw88 is on a distinguished road
Warped rotor totally makes sense given your last sentence. Check the rotor runout.
Craig, Tucson AZ
New Buyers Please Read
Originally Posted by JitteryJoe View Post
Buying the car is going to turn out the be the least expensive part of this experience. Fun though.
Jump to top enderw88 is offline   Reply With Quote
Old Wed, Aug-01-2012, 04:19:27 AM   #9
sharde26
Hmmm, I don't have the required dial to check the runout so I'll try swapping the passenger and driver's side rotors to see if the problem follows the part. Sound good?
Old Wed, Aug-01-2012, 12:59:30 PM   #10
enderw88
Rolling Restorer
enderw88's Avatar
Or you could go to harbor freight and buy this dial indicator for $35.
And not pose a safety risk to yourself and everyone around you. This should really be a required tool if you change your own pads.
Craig, Tucson AZ
brake, caliper, drag, front
Discussing Continuing Brake Trouble in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
