Old Fri, Mar-12-2010, 01:57:21 AM   #11
ShafferMD
M3 Enthusiast
Reputation: 0 ShafferMD is on a distinguished road
Default Me too...
I had the same problem a month ago after turning around in a parking lot on a slight grade. It only rubbed for a brief moment and hasn't happened since.
FWIW, I am installing RE Wheel Spacers 10mm rear/ 15mm front to completely avoid this problem from ever happening again (plus it looks great!).
Here's my original post:
http://m3forum.net/m3forum/showthread.php?t=299867
Let me know if you ever establish root cause and what your corrective actions are...
Good Luck!
SOLD:
2003 6MT ///Carbonschwartz Metallic : Black Nappa : Premium Package : Cold Weather Package
PERFORMANCE: 245/275 PS || CDV Delete || Clutch Stop || BMW SSK || RE RTAB's || APPEARANCE: Invisibulbs || AC Schnitzer Pedals || Custom Toolkit w/ M3Forum Decal || Painted Reflectors || 55W Xenon Matched Fogs CONVENIENCE: Eurotray || Dynavin V4 DVD/NAV
Ask me anything about Powdercoating!
PM me for Metric Clutch Stop sourcing
Jump to top ShafferMD is offline   Reply With Quote
Old Wed, Sep-24-2014, 04:59:25 PM   #12
benfica8814
Reputation: 0 benfica8814 is on a distinguished road
Default Re: Front tire rubbing lower spring pad
Hey guys sorry to hijack this thread but i have a similar problem. My car was originally lowered so i re installed the stock suspension. After completion i go to install my tires and the passenger side tire does not fit. It is hitting the spring perch. Is it possible i screwed something up? I just re aligned the spring on the orginal markings on the rubber, and made sure the shock was completely seated. It can only go in one way right? The driver side clears but barelly. Also im running 245/40/19 in the front.
Thanks!
Jump to top benfica8814 is offline   Reply With Quote
front, lower, pad, rubbing, spring, tire
Front tire rubbing lower spring pad chemworldx Faults, Fixes and DIY 0 Sun, Mar-01-2009 02:21:11 AM
PSS9 VS Lower Spring which one no noise? garychen0919 E46 M3 (2001-2006) 1 Thu, Oct-30-2008 07:07:08 PM
How much can I lower without rubbing with Le37 10.5 rears w/25mm offset? SMG78 E46 M3 (2001-2006) 0 Sun, Feb-04-2007 05:23:30 PM
lux pkg and rear spring pad ///sleeper E36 M3 (1992-1999) 1 Sun, Mar-19-2006 02:35:18 AM
Anyone have problems w/ front tires rubbing spring perch? ziggy723 E46 M3 (2001-2006) 2 Sat, Aug-20-2005 09:31:08 PM
Discussing Front tire rubbing lower spring pad in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
