Old Fri, Mar-12-2010, 08:09:13 AM   #11
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Originally Posted by kkamakasi View Post
so, when replacing regulators, should i disconnect the battery since I'm going to be removing/installing airbags?
yes.. remove the gnd of the battery. but just make sure you
lower the window approx. 3-4"
before removing the gnd. removing the airbag while the battery is connected may give you an airbag light later on your dash.
Tischer aka GetBmwParts
Old Fri, Mar-12-2010, 02:12:56 PM   #12
kkamakasi
울산박
kkamakasi's Avatar
Reputation: 0 kkamakasi is on a distinguished road
South Korea
thnks.. heading to the garage right now to get started.
Jump to top kkamakasi is offline   Reply With Quote
Old Fri, Mar-12-2010, 03:36:09 PM   #13
kkamakasi
울산박
kkamakasi's Avatar
South Korea
is this bracket supposed to have any play? mine moves around about 1-2mm in each direction.
Old Fri, Mar-12-2010, 05:01:59 PM   #14
kkamakasi
울산박
kkamakasi's Avatar
South Korea
anyone?
Old Mon, Jul-09-2012, 05:16:28 AM   #15
daytonaviolet
OEM CSL Whoore
Default Re: DIY e46 front window regulator install
anyone?
i know this is an old thread, but the correct information may help someone else some day. if thats the driver side window.. then the nut, metal plate and plastic clip in your pic is actually backwards. it should be on the other side. 1-2mm play is okay. it will not move once the bolt is in place. i'll post some pics as i changed my regulator today. more pictures here
Old Fri, Aug-17-2012, 03:34:41 PM   #16
boardmandan
Reputation: 0 boardmandan is on a distinguished road
Hopefully this will help someone out if they ever have to do this. When I took my window out, pieces fell out into the bottom of the door and I couldn't find out where they went.
Pics of what fell out are here:
http://www.m3forum.net/m3forum/showthread.php?t=417654
Here is what the passenger side looked like. I had to take the passenger door panel off to figure out that the pieces that fell out were held in with a rubber o-ring which had disintegrated. The aluminum piece with the fine groove goes up against the fine grooves in the piece on the window regulator. The cam goes inside.
Summary: Check your o-ring before you take the window out and it should help keep parts from falling out and keep the window from going out of alignment.
Jump to top boardmandan is offline   Reply With Quote
Old Thu, Mar-06-2014, 06:25:11 AM   #17
tomax
TOMAX
Reputation: 0 tomax is on a distinguished road
Great DIY I did my first one yesterday in about 2 hrs.
Thanks all.
Jump to top tomax is offline   Reply With Quote
Old Wed, Dec-10-2014, 01:34:05 AM   #18
SunD3v1L
hi
SunD3v1L's Avatar
Reputation: 0 SunD3v1L is on a distinguished road
Italy
Help please.
How do you remove the window if the window is stuck down and you can't access the E7 bolts?
Jump to top SunD3v1L is online now   Reply With Quote
Old Fri, Jan-02-2015, 10:01:16 PM   #19
cglhut
cglhut's Avatar
Reputation: 0 cglhut is on a distinguished road
Originally Posted by SunD3v1L View Post
Help please.
BUMP! Need help with this too!
2003 sterling grey/black stage 2.5 HPF M3: On the way
2002 IR/IR stage 3.5 active autowerks SC M3: Gone
2003 IR/black M3: Gone
Jump to top cglhut is offline   Reply With Quote
Old Fri, Jan-02-2015, 10:05:45 PM   #20
SunD3v1L
hi
SunD3v1L's Avatar
Italy
Replied to your PM.
diy, e46, front, install, regulator, window
Power window motor/regulator install Cadeez99M3 E36 M3 (1992-1999) 17 Wed, Aug-28-2013 12:57:03 PM
e46 passenger side window regulator davem3smg Parts for Sale/Wanted 0 Thu, Jul-26-2007 05:23:30 AM
Need help: Replacing Window Regulator achung E46 M3 (2001-2006) 1 Tue, Oct-03-2006 01:57:05 PM
how to remove window regulator? spudski67 E36 M3 (1992-1999) 1 Sun, Sep-17-2006 03:05:24 AM
Do I need a new window regulator? mpegripper E46 M3 (2001-2006) 5 Fri, Jun-16-2006 08:40:21 AM
Discussing DIY e46 front window regulator install in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
