Old Mon, Oct-22-2018, 11:09:57 PM   #1
Sprp85
Reputation: 0 Sprp85 is on a distinguished road
Default Place to install Vincebar/CMP/Mason Braces in MD?
Hey all,
I have recently picked up a 06 M3.
The car has TMS plates welded on and was told that it was done in preventative manner.
Now, while reading upon rear crack issues, I thought why not do top reinforcement to really bulletproof the issue for good?
However, Vincebar / CMP bar seems to require extensive installation procedure and saw that not many shops have enough hands on experience in installing them vs. Just welding plates on underneath.
Can anyone recommend a shop for the top bar fix?
On a second thought, Mason braces seems to be another decent alternative, according to many. And the braces having a plus side of being not tooooooo difficult or complicated to install. So I would assume there will be more shops that might be willing to perform the job?
Anyhow, any inputs are much appreciated and thank you in advance!
Sent from my Pixel 2 XL using Tapatalk
06 TiAg M3-Apex EC-7/PSS10/Besian/TTFS
10 Hyundai Sonata-A-to-B
11 Alpineweiss 128i-GONE
05 Chili Red R53-GONE
Jump to top Sprp85 is offline   Reply With Quote
Old Mon, Oct-22-2018, 11:22:17 PM   #2
rbmwiv
rbmwiv's Avatar
Reputation: 0 rbmwiv is on a distinguished road
Default Re: Place to install Vincebar/CMP/Mason Braces in MD?
The good thing about the cmp kit vs the mason bar is you have solid steel mounts at all 4 corners. I am fixing to do the cmp either start this weekend or the next. It will be on the lift a few days. The plus about the mason bar is it can be installed without removing the rear suspension like you do for the Vince bar or cmp kit. I am doing the install my self. It comes with very clear instructions on what order and exactly where to cut. Every single step with pictures are included. Idk who to recommend as I wouldnít trust anyone else to put it in I have been welding for 30+ years honestly I would recommend the mason bar since itís really easy to install and it can be installed in under a day if you have done one before and I donít see why any competent shop will mess it up because itís a bolt in brace vs weld in. Absolutely no welding for the mason bar.
Jump to top rbmwiv is offline   Reply With Quote
Old Mon, Oct-22-2018, 11:55:38 PM   #3
MFahrer
MFahrer's Avatar
Reputation: 0 MFahrer is on a distinguished road
Piper Motorsports is probably a safe bet.
Maybe RRT Racing.
Neither are in MD but are close enough.
Walnut Motor Works x SCL Racing
2001 M3, on a diet, CSL wannabe, Ground Control race/track, Hotchkis, Powerflex, Project Mu, Solid Design, Autosolutions, APEX, Bimmerworld
Jump to top MFahrer is offline   Reply With Quote
Old Tue, Oct-23-2018, 01:31:10 AM   #4
Sprp85
That reason was the most common one I've seen when people went for Mason vs. CMP/Vince. It would be great if you can post feedbacks when you are done!
Maybe RRT Racing.
I will get in touch with RRT to see... they aren't THAT far...
Thank you all
Old Tue, Oct-23-2018, 01:54:10 AM   #5
rbmwiv
rbmwiv's Avatar
I will definitely post feedback when I do it Iíll try to document it.
Old Tue, Oct-23-2018, 02:02:42 AM   #6
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
Coyne Performance in Harrisburg PA. Youíll find nothing but great reviews. Heís done plenty of these, including mine.
Jump to top Chapelle is offline   Reply With Quote
Old Tue, Oct-23-2018, 02:25:55 AM   #7
lmtfi
lmtfi's Avatar
RRT in Va.
Old Tue, Oct-23-2018, 02:50:35 AM   #8
stash1
Reputation: 0 stash1 is on a distinguished road
Iíll 2nd, 3rd, and 4th that! Go see Matt up in PA...itís not that far, and you wonít be disappointed w/the price or the work! Tell him Stan sent you!
'04 AW/IR...some mods
Jump to top stash1 is online now   Reply With Quote
Old Thu, Oct-25-2018, 12:59:43 AM   #9
eacmen
York Automotive in Mt Airy, MD. Tell them Peter sent you.
They do all the track prep work on my M3. Owner is former racer. Their rates are reasonable (RRT rates are nuts).
Jump to top eacmen is offline   Reply With Quote
Old Thu, Oct-25-2018, 02:32:44 AM   #10
Sprp85
Thank you all for your inputs.
I will start to reach out to the shops and get some quotes.
Thanks again all!
Discussing MK20 ABS unit differences in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
