Old Mon, Jun-17-2019, 11:27:30 PM   #1
ExclusiveAuto
Reputation: 0 ExclusiveAuto is on a distinguished road
Default What is the m3forum-preferred e46 m3 RSM setup?
throwing some rear shocks on the car and figured it would be a good time to upgrade the rear shock mounts while im in there. Just curious what the preferred RSM setup is here on the forum. THanks!
Jump to top ExclusiveAuto is offline   Reply With Quote
Old Mon, Jun-17-2019, 11:34:10 PM   #2
Default Re: What is the m3forum-preferred e46 m3 RSM setup?
Nothing wrong with stock. Just replace them as they age, they're cheap. Get some reinforcement plates.
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Tue, Jun-18-2019, 12:08:53 AM   #3
ExclusiveAuto
any recommendation on reinforcement plate?
Old Tue, Jun-18-2019, 12:24:42 AM   #4
Dee514
Dee514's Avatar
Reputation: 0 Dee514 is on a distinguished road
Tibet
I went with the rogue RSM. It makes removing the shocks easier
Jump to top Dee514 is offline   Reply With Quote
Old Tue, Jun-18-2019, 12:56:00 AM   #5
STAATS
STAATS's Avatar
ECS Tuning Ultimate RSM Monoballs are awesome... can buy them in a kit with reinforcement plates as well... highly recommended
STAATS
Old Tue, Jun-18-2019, 01:04:41 AM   #6
ExclusiveAuto
https://www.ecstuning.com/b-ecs-part...002542ecs01kt/
are these the ones you like?
Old Tue, Jun-18-2019, 01:32:14 AM   #7
eacmen
I have the ground control race mounts on my track car (https://groundcontrolstore.com/produ...ace-mount-pair). No issues so far. They have street options as well. No reinforcement needed with the GC mounts.
Jump to top eacmen is online now   Reply With Quote
Old Tue, Jun-18-2019, 01:38:26 AM   #8
ExclusiveAuto
Thank you very much for the suggestions!
Old Tue, Jun-18-2019, 02:18:06 AM   #9
SQ13
I might be able to sell you a pair of Rogue Engineering street RSMs if you’re interested. I should be done with coilover install on the street car tomorrow, and need to make sure the monoball RSMs I’m going to use aren’t noisy first.
Old Tue, Jun-18-2019, 02:21:09 AM   #10
STAATS
STAATS's Avatar
Originally Posted by ExclusiveAuto View Post
Correct
STAATS
Discussing What is the m3forum-preferred e46 m3 RSM setup? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
