Old Mon, Jun-17-2019, 09:47:12 PM   #1
bihi
Reputation: 0 bihi is on a distinguished road
Default Stock shocks vs koni/bil
I'm out here in Hawaii so shipping sucks. There are very low miles stock shocks on Craiglist right now. Sub 1k miles low. Are the koni/bil much better than the stock shocks or not?
Sent from my Pixel 3 XL using Tapatalk
Jump to top bihi is online now   Reply With Quote
Old Mon, Jun-17-2019, 09:51:06 PM   #2
Default Re: Stock shocks vs koni/bil
For daily driving, no. Billys (B6, not B4) probably would be worse (harsher) to you if luxury/comfort are paramount. Konis are pretty good.
What springs will you be running? If you're keeping things pretty stock, I would just get the set of Sachs and be done. The robust billys aren't needed and the adjustment with the konis isn't needed.
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Mon, Jun-17-2019, 09:55:16 PM   #3
bihi
Right now probably just some h&r for a slight drop once i get the wheels i want The stock shocks are still in there and it's at 118k.
Old Mon, Jun-17-2019, 10:34:00 PM   #4
m3nt0s
Registered Detailer
Reputation: 0 m3nt0s is on a distinguished road
For an otherwise stock suspension, Koni Yellows are effectively a no-compromise upgrade for comfort.
05 E46 M3 Coupe - Jet Black/Black, SMG, Karbonius Airbox, 18" RG-R, AS3 235/265, Koni Yellow, Beisan, Structural Foam, CSL/full SMG coding, SAP Delete, Xtrons
03 E39 530i - Black Sapphire/Black, Sport Package, 5MT Swapped (DD)
Previous:
09 E91 328i Space Gray/Chestnut, N52, Auto, xDrive, Xenons, no iDrive, TPMS Module Delete
11 Mustang GT Premium
09 N51 128i
04 S60R GT S2+
95 854 Turbo
Jump to top m3nt0s is offline   Reply With Quote
Old Thu, Jun-20-2019, 09:14:34 PM   #5
CarbonVert
CarbonVert's Avatar
Reputation: 0 CarbonVert is on a distinguished road
I have Bilstein B6 dampers paired with OEM springs, I couldn't be happier with the way the car rides.
Quality Review here:
http://www.m3forum.net/m3forum/showthread.php?t=506953
Jump to top CarbonVert is offline   Reply With Quote
Discussing Stock shocks vs koni/bil in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
