Old Mon, Jun-17-2019, 08:47:23 PM   #11
Good
@GOOD_M3
Good's Avatar
Default Re: Smg hydraulic unit rebuild
Originally Posted by SMG cog light View Post
good job. Did you replace the large O ring on the bottom of the pump and the small O ring on the pressure relief valve? I didn't see that mentioned on the post. Also a updated hydraulic fluid pressure decay live data test results would be much appreciated.
I have not replaced any seals yet, this is pretty much my progressing DIY. So far I’ve disassembled the whole unit aside from the Bosch internal pump, I will complete the rebuild later this week once I’ve received my replacement seals. One I've rebuilt and installed the unit I'll be sure to provide my data results.
EXTERIORV÷RSTEINER CSL BUMPER | MILE END CSL 1X1 DIFFUSER & FLIPPERS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OE SNORKEL + CSL DUCTING | VANOS BEISAN LOCKDOWN
TRANSMISSION ▌SMG HCU RELOCATED & REBUILT W/ NEW SEALS, ACCUMULATOR & BURKHART KIT
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V3 COILOVERS | ROGUE RSM | GROUNDCONTROL STREET CAMBER PLATES | SDW RTABS
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | STOCK2 | SPORT (GEN 2) SEC 3
BRAKES ▌CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌OEM CSL BBS 19" | 75MM ECS/TMS WHEEL STUDS
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Old Mon, Jun-17-2019, 09:00:06 PM   #12
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Nice job! Love seeing threads done properly with pictures and links.
Dam that accumulator is pricey!!
Here's some SMG Viton O-ring links.
2000-2006 BMW E46 M3 SMGII Repair KIT- Viton Seals Hydraulic Pump-$80
https://www.ebay.com/itm/2000-2006-B...I/323655639339
2000-2006 BMW E46 M3 SMGII Viton O-ring kit for Solenoids-$99
https://www.ebay.com/itm/18384252061...m=183842520619
Old Mon, Jun-17-2019, 09:12:14 PM   #13
SMG cog light
I found a source for a brand new OEM accumulator for $675. I forgot to save the site. When I get a chance i will look for it again and share the link. The solenoid O ring kit is good for individuals reconditioning their pumps. I recommended harbor freight and amazon viton O rings because they are way cheaper and also can be used for other parts in the HCU that uses O rings and you can use it in other parts of the car (like the smg reservoir line 2x O rings if it's leaky) and mainly because I recondition so many pumps, so it was better for my situation.
Jump to top SMG cog light is offline   Reply With Quote
Old Mon, Jun-17-2019, 09:16:47 PM   #14
SMG cog light
Originally Posted by Good View Post
I have not replaced any seals yet, this is pretty much my progressing DIY. So far Iíve disassembled the whole unit aside from the Bosch internal pump, I will complete the rebuild later this week once Iíve received my replacement seals. One I've rebuilt and installed the unit I'll be sure to provide my data results.
oh ok. I recommend you do a resistance reading on the solenoids while they are out and also check the solenoids to make sure they click. They rarely go bad but I have found 2 solenoids out of 12 pumps that were sticking/failed, so they do happen although rare.
Old Mon, Jun-17-2019, 09:26:40 PM   #15
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Nice work. As you can see, the physical unit is surprisingly simple inside.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Tue, Jun-18-2019, 12:20:24 AM   #16
kokgo20
kokgo20's Avatar
Great thread, i guess i should rebuild mine for the hell of it 123K miles so far
Need the link to the cheaper accumulator $1000 is quit high for that thing.
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Tue, Jun-18-2019, 01:29:05 AM   #17
SMG cog light
I found it.
https://cars245.com/en/item/bmw-2153...e-accumulator/
I also will update the smg maintenance recondition thread with this website.
This website also sells the M3 csl reservoir for $89 vs. $130 at other websites
Old Tue, Jun-18-2019, 01:41:58 AM   #18
SMG cog light
i wonder if this oil pressure sensor ($31 vs. $100 at other sites) would work on the HCU.
Same number printed on both sensors:
53CP06-02
https://pt.aliexpress.com/item/32597672477.html
Old Tue, Jun-18-2019, 01:36:58 PM   #19
andrewrivera141
Reputation: 0 andrewrivera141 is on a distinguished road
Are accumulators meeting changed because there bad or just because? I thought it was too be changed if the pressure was not staying or at a certain level that isn't drivable. I've been meaning to do this as I have had the Burkhart Motor sitting in the box for a year, waiting to do the rehaul until I started to try and save for the relocation kit. Smh. I need to get shit done already. And how does the solenoid unit get tested, by magnets you can open and close the contacts? Thanks in advance
Sent from my Pixel using Tapatalk
Jump to top andrewrivera141 is offline   Reply With Quote
Old Tue, Jun-18-2019, 01:49:21 PM   #20
This looks like a pretty fun rebuild!
Discussing Smg hydraulic unit rebuild in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
