Old Mon, Jun-17-2019, 07:19:31 PM   #1
Good
@GOOD_M3
Good's Avatar
Default Smg hydraulic unit rebuild
DIY: Complete (inside/out) SMG Hydraulic Pump Rebuild
Where to Purchase Replacement Parts:
Accumulator
https://www.fcpeuro.com/products/bmw...or-21532229716
Motor
https://burkhart-engineering.com/54111en
Temperature Sensor
https://burkhart-engineering.com/54112en
Pressure Sensor
CURRENTLY LOOKING FOR A MANUFACTURE SMGSOCIETY PRESSURE SENSOR DOES NOT WORK!
Burkhart Performance Hydraulic Fluid
https://burkhart-engineering.com/54134en
Bosch Gear Shaft Inner Pump Seals (x2)
SHOOT ME A PM FOR GEAR SHAFT SEALS
Sachs High Performance Grease (For Pump/Motor Coupler)
https://www.pelicanparts.com/More_In...Y&fs=0&SVSVSI=
Internal Solenoid O-rings (x4)
https://www.smgsociety.com/product/s...e46-m3-smg-ii/
All Other Required O-Rings
https://www.harborfreight.com/180-pi...kit-67525.html
https://www.ebay.com/itm/2000-2006-BMW-E46-M3-SMG-Repair-Hydraulic-Pump-Gear-Shaft-Set-CNC-Carbon-Steel/183688111165?hash=item2ac4aa243d:g:AjAAAOSweedcZ7K ~
1) First, I removed the accumulator to eliminate the awkward shape of the pump for an easy disassembly.
To remove the accumulator you will need to turn the 17mm nut at the end of the component.
Be very careful when removing the accumulator as the nut on the end can snap off easily.
I recommend proceeding with the disassembly in a plastic tub to catch the leftover hydraulic fluid.
When removing the Solenoids, make sure to label each one so you won't mix them up when reinstalling.
I decided to clean the coupler, housing gasket, housing piece, screws and HCU block.
Inner Gear Shaft Seal Wear: (SMG 97,000 Miles 2006 M3)
If you are NOT replacing your accumulator, make sure you replace the O-Ring on the thread of the accumulator.
My SMG unit has been relocated to the 'drug bin' and be I will be proceeding to install the Burkhart motor from the drug bin.
EXTERIORVÖRSTEINER CSL BUMPER | MILE END CSL 1X1 DIFFUSER & FLIPPERS
ENGINE ▌TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OE SNORKEL + CSL DUCTING | VANOS BEISAN LOCKDOWN
TRANSMISSION ▌SMG HCU RELOCATED & REBUILT W/ NEW SEALS, ACCUMULATOR & BURKHART KIT
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V3 COILOVERS | ROGUE RSM | GROUNDCONTROL STREET CAMBER PLATES | SDW RTABS
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | STOCK2 | SPORT (GEN 2) SEC 3
BRAKES ▌CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌OEM CSL BBS 19" | 75MM ECS/TMS WHEEL STUDS
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/UCOW...3N7QDfZ5NSzriA
Journal: http://www.m3forum.net/m3forum/showthread.php?t=599036
Old Mon, Jun-17-2019, 07:33:26 PM   #2
CheckABS
Volks or bust!
Reputation: 0 CheckABS is on a distinguished road
Default Re: Smg hydraulic unit rebuild
This is going to be GOOD!
See what I did there? Haha, in all seriousness, thank you for the write up and pictures!
ITRs | NSX | M3s | M5
IG: Book_a_Room
For Sale:
Volk TE37SL 18x9.5 +35 squared
Volk CE28N 19s
Jump to top CheckABS is offline   Reply With Quote
Old Mon, Jun-17-2019, 08:19:49 PM   #3
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Looking forward to the results. Found this on eBay
https://rover.ebay.com/rover/0/0/0?m...2F183842520235
Old Mon, Jun-17-2019, 08:23:51 PM   #4
Good
@GOOD_M3
Good's Avatar
I saw this listing too, but for an extra $79 it only includes enough seals to refurbish one of the four solenoids. SMG Society offers replacement solenoid seals for $13/set ($52 for all four solenoids).
Old Mon, Jun-17-2019, 08:24:30 PM   #5
0-60Motorsports
Bahrain
Originally Posted by Good View Post
I saw this listing too, for an extra $79 it only includes enough seals to replace one solenoids seals of the 4 required when rebuilding. SMG society offers replacement solenoid seal for $13/set.
Ah good to know, glad I didn’t buy them.
Old Mon, Jun-17-2019, 08:39:30 PM   #6
oceansize
Kwisatz Haderach
oceansize's Avatar
Thanks Good. All of my stuff to do the same has arrived or is en route so I'll be referring back to this I'm sure.
2003 M3 Convertible SMG w/Hardtop | GC Coilovers and Camber Plates | ESS VT1-475 Gen 3 Supercharger | Stoptech Brakes
Apex ARC-8 19" Hypersilver | CSL SMG (and 255) Tune | RE Diablo Exhaust w/ SS Tips | RE Rasp Pipe
Storm Motorwerks SMG Paddles | Two Tone Black/Grey Interior | Alcantara E-brake Boot
Very Recent Maintenance: FCABs | FCAs | RTABs | Motor Mounts | PS Hoses | Inner/Outer Tie Rods | End Links | Vanos Solenoid |
Driveshaft R&R | Flex Disc | Fan Clutch | Trans Fluid | Diff fluid
Old Mon, Jun-17-2019, 08:39:41 PM   #7
Good
@GOOD_M3
Good's Avatar
I’m going to work on bringing together a complete SMG Pump rebuild kit including the 12 replacement internal solenoid seals, 4 main external solenoid seals, the two odd shaped internal pump seals and the external pump o ring (attached to the Bosch pump internal unit). We shouldn’t have to purchase a 180 piece o-ring kit from harbor freight and test fit different seals just to rebuild these HCU’s.
Old Mon, Jun-17-2019, 08:44:06 PM   #8
oceansize
Kwisatz Haderach
oceansize's Avatar
Didn't you also have a DIY for the relocation kit? I thought I saw that but can't seem to find it. My relocation kit is on the way as well.
Old Mon, Jun-17-2019, 08:44:23 PM   #9
SMG cog light
good job. Did you replace the large O ring on the bottom of the pump and the small O ring on the pressure relief valve? I didn't see that mentioned on the post. Also a updated hydraulic fluid pressure decay live data test results would be much appreciated.
Jump to top SMG cog light is offline   Reply With Quote
Old Mon, Jun-17-2019, 08:45:25 PM   #10
Good
@GOOD_M3
Good's Avatar
I did a semi-DIY for the relocation on my Journal.
Discussing Smg hydraulic unit rebuild in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
