Old Sun, Jun-16-2019, 09:59:17 PM   #11
mrgizmo04
mrgizmo04's Avatar
Default Re: Very Rough Idle
Is this after replacing the coils?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Jun-16-2019, 10:22:43 PM   #12
ThunderMoose
Id replace coils
#67 2017 NASA TX TT3 Champion
Old Sun, Jun-16-2019, 10:23:08 PM   #13
CraigMak
CraigMak's Avatar
Reputation: 0 CraigMak is on a distinguished road
No, this is before. I wanted to check codes before buying the coil/spark plug kit.
________________________________________________
2001 BMW M3 Vert Imola Red|Black Grills&Vents|Custom German Plate|19" Deep Dish Rims|CF Roundel|
1998 BMW 328i |M3 Bumper|Chrome Grill|Clear Corners|eyebrows|Trunk Lip|Euro Fogs|German Plate|
Jump to top CraigMak is offline   Reply With Quote
Old Sun, Jun-16-2019, 10:25:02 PM   #14
CraigMak
CraigMak's Avatar
Originally Posted by ThunderMoose View Post
Id replace coils
Really? I'm getting misfires on all cylinders. That doesn't seem like coils to me.
Old Tue, Jun-18-2019, 06:16:24 AM   #15
CraigMak
CraigMak's Avatar
More data from the code reader:
I got a new code: P0300 RANDOM/MULTI CYLINDER MISFIRE
I read live data and got the following:
LOAD_PCT 21.2%
ECT 59
SHRTFT1 0.0%
LONGFT1 0.8%
SHRTFT2 0.0%
LONGFT2 1.6%
RPM 899/MIN
SPARK ADV 21.5
IAT 38
MAF 5.69G/S
TP 0.0%
AIR_STAT OFF
02S11 0.155V
O2S12 0.04V
O2S21 0.020V
O2S22 0.025V
SHRTFT12 99.2%
SHRTFT22 99.2%
SHRTFT21 0.0%
SHRTFT11 0.0%
Saw some tests labeled $01, $02, $03, $05
TEST $01 DATA
MAX TEST
VALUE 3
MIN --
MAX 2
FAIL
TEST $02
MAX TEST
VALUE 1719
MIN--
MAX 2000
PASS
TEST $03
MAX TEST
VALUE 350
MN --
MAX 350
PASS
TEST $05
MIN TEST
VALUE 44
MIN 41
MAX --
PASS
There was no $04
Old Wed, Jun-19-2019, 06:25:04 AM   #16
CraigMak
CraigMak's Avatar
Any ideas on what to trouble shoot next? I'm at a loss with this one. Multi cylinder random misfires and multi cylinder misfires with fuel shut off. Definitely doesn't not seem like the coils.
Plus it pretty much came out of nowhere.
Is it possibly bad gas? It happened right after I filled up. Although it was Chevron. Just grasping at possibilities due to the coincidence.
Old Wed, Jun-19-2019, 12:04:07 PM   #17
Get a BMW specific code reader hooked up to it.
I doubt it's gas related.
Old Wed, Jun-19-2019, 01:36:53 PM   #18
PenguinScotty
PenguinScotty's Avatar
Reputation: 0 PenguinScotty is on a distinguished road
Austria
Blew my o2 Heater fuse at the track, causing the o2s to effectively no longer function. This resulted in misfires on all cylinders and the same fuel code as yours. I did get a o2 sensor heater wire code though, so maybe it's not it, but worth checking out the o2 sensors, to see if they're functioning properly/what they are reading.
'98 E36 M3 Evo - Techno Violet, '02 E46 M3 - Titansilber, '05 E46 M3 - Titansilber
Jump to top PenguinScotty is online now   Reply With Quote
Old Wed, Jun-19-2019, 04:52:57 PM   #19
jdamore44
jdamore44's Avatar
Reputation: 0 jdamore44 is on a distinguished road
I had 1 bad coil and got misfires on multiple cylinders. Don't rule out the coils.
1983 320iS - SOLD
1997 328iS Sport - SOLD
2003 Steel Grey Metallic M3 6MT Coupe, Black Interior
Jump to top jdamore44 is online now   Reply With Quote
Old Wed, Jun-19-2019, 05:45:57 PM   #20
sapote
check fuel pressure with gauge near the pump blumping system -- should be 5 bar or 72psi
Jump to top sapote is online now   Reply With Quote
Discussing Very Rough Idle in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
