Pacific For events in California, Idaho, Nevada, Hawaii, and Alaska. |
Got ///M?
![]() Location: Sunny Diego!
Hi all,
Anyone from recent CMP group-buy installed their kits in SoCal, shop used? Or have recommendation on the shop? Thanks.
![]() 04 CarbonBlack/ImolaRed |
Sponsored Links |
Interested as well. I would guess Matt at Techcraft (Irwindale) could handle it as he fabs cages I believe.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · ~3100lbs · JOURNAL ![]() Evolve-R Alpha N · Evolve CF CSL Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 2.5" sect 1· SS unres 2.5" sect 2 · SCZA 2.5" sect 3 · Besian · RE pulleys/fan delete · CSL battery Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway · F & R strut bars · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack Last edited by TboneM3; Tue, May-07-2019 at 11:04:19 PM. |
I've done in norcal (this one not diy) if anyone interested.
'85 528e 164k miles (sold) '05 M3 6MT coupe All DIY: VANOS, WPC rod bearings, full SS (SS stepped V1 headers, catted S1, stock S2, SS sport), AFD E85 Proflex kit, Ohlins R&T/Hyperco 375f Swift 672r/GC street tops and camber plates, ST40 355 pfc08, 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Sachs clutch/flywheel, rear main, Beyer driveshaft, valve adjustment, cooling refresh. Happy to help with VANOS or any other DIY job around NorCal. Have various specialty tools (VANOS, RTAB, engine bar, valve adjustment, tranny jack, ball joint separator, pilot bearing puller, tap&die kit, etc). |
#4 | |
Got ///M?
![]() Quote:
Which kit/kits did you order? I think there were couple guys from LA area on the group-buy, wonder where they get theirs installed.
#5 | |
![]() Quote:
Word of advice on the subframe reinforcement from top for anyone looking to do it, I didn't follow my advice ![]() Sent from my SM-G950U using Tapatalk
#6 | |
Got ///M?
![]() Quote:
Thanks for the info. I am doing the whole thing; topside, plate reinforced on the bottom, also the solid bushing so the subframe needs to come down. Hoping someone in SoCal had done this using CMP kits. Sent from my iPhone using Tapatalk
#7 |
![]() Location: Walnut + Rowland Heights, CA
It's been a while since this was posted but I hope this helps. I didn't join the GB since I didn't have a M3 yet but I purchased their subframe reinforcement plate, subframe bushings and RTAB 2 weeks ago and just had Matt @ Tech Craft install it. Everything went smoothly and he was really impressed with the overall kit, especially the RTAB bushing.
S54 E36 Build ![]() |
#8 |
I think I saw some pics of the installed reinforcements on your car that Matt posted up on Instagram. They look good. Lots of coverage.
#9 |
Yeah, that’s the one!
#10 | |
Got ///M?
![]() Quote:
Bookmarks |
Thread Tools | |
Display Modes | |
