Old Fri, May-10-2019, 01:49:15 AM   #21
youinreverse
Reputation: 0 youinreverse is on a distinguished road
Default Re: J-Fiber CF Driveshaft Thread!
I知 having vibration issues with mine. : (
Jump to top youinreverse is online now   Reply With Quote
Old Fri, May-10-2019, 01:50:11 AM   #22
WALKD_U
WALKD_U's Avatar
What's wrong?
Rides:
2005 AW/IR M3
BMB Stage 4
940whp/765wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
Instagram:
M3HNGRY
EURO.techniks
<a href=https://www.instagram.com/m3hngry/ target=_blank>M3HNGRY</a>
Old Fri, May-10-2019, 01:52:53 AM   #23
youinreverse
Originally Posted by WALKD_U View Post
What's wrong?
I知 heading out of the house to go put my driveshaft back in. I値l write a longer/more detailed post when I get back
Old Fri, May-10-2019, 01:53:51 AM   #24
WALKD_U
WALKD_U's Avatar
Keep us posted! Lmk if I can help in anyway
Rides:
2005 AW/IR M3
BMB Stage 4
1996 BLU/BLK M3
NA Bolt-ons
Instagram:
M3HNGRY
EURO.techniks
Old Fri, May-10-2019, 03:50:29 AM   #25
kokgo20
kokgo20's Avatar
When some of you guys say no vibration, did you have vibration on the stock DS? if so how old or many miles are on the stock ones?
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Old Fri, May-10-2019, 03:38:17 PM   #26
WALKD_U
WALKD_U's Avatar
No vibration with stock or aftermarket. Car only have 56k with all poly bushings everwhere you can think of.
Rides:
2005 AW/IR M3
BMB Stage 4
1996 BLU/BLK M3
NA Bolt-ons
Instagram:
M3HNGRY
EURO.techniks
Old Fri, May-10-2019, 03:43:02 PM   #27
Drewster
Drewster's Avatar
For this driveshaft, it looks like there's no U-Joint or CV joint on the transmission? Does the giubo take the stress of flexing down to the diff?
Old Fri, May-10-2019, 05:30:04 PM   #28
GrendelsbaneM3
GrendelsbaneM3's Avatar
Reputation: 0 GrendelsbaneM3 is on a distinguished road
No vibrations in OEM driveshaft or the J-Fiber one. Solid for me.
2004 Silver M3 / SMG / TC Kline DA Coilovers / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / ALPS Jammers / Clear Bumper Reflectors / Zionsville Competition Cooling Kit with Offset Fan / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune / ESS 575 Supercharger / Stillen AP Racing BBK / J-Fiber Carbon Fiber Driveshaft
Jump to top GrendelsbaneM3 is offline   Reply With Quote
Old Fri, May-10-2019, 08:48:35 PM   #29
Cristov9000
Reputation: 0 Cristov9000 is on a distinguished road
I think ideally you would want the output of the trans pointed at the input to the diff. Not sure if the e46 M3 is set up that way I read somewhere where a giubo can take up to 2 degree of misalignment max but the more misalignment you have shorter the life of the giubo.
I had an issue when I first engine swapped my e30 and ate an e46 M3 giubo in like 5k miles, I had to lower the trans mounts to get the correct angle for the driveshaft. I stuck a laser pointer on the trans output until it was pointing where I needed it to. Anyone ever done that with an e46 M?
e30sport.net
'86 325es - M-Technic 1 - S54B32 - 6speed
'89 325is - MIndividual - M20B25 - 5speed
'15 Porsche GT3 - PDK - Daily driver
Sold:
'15 M4 - S55B30 - 6speed
'08 M3 - S65B40 - DCT
'08 Audi RS4 - 6speed
Jump to top Cristov9000 is offline   Reply With Quote
Old Fri, May-10-2019, 09:14:19 PM   #30
WALKD_U
WALKD_U's Avatar
I have not but I know my diff sits alittle lower then OEM due to my Reinforcement Brackets. We are still using the stock Guibo and diff side still have a CV joint. Only thing we got rid of is the Center Support Bearing and U-joint.
Rides:
2005 AW/IR M3
BMB Stage 4
1996 BLU/BLK M3
NA Bolt-ons
Instagram:
M3HNGRY
EURO.techniks
Copyright ゥ1999-2017 M3Forum.com
Discussing J-Fiber CF Driveshaft Thread! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
