Old Wed, Jan-09-2019, 10:31:38 PM   #21
flyweight
Reputation: 0 flyweight is on a distinguished road
Default Re: M3Forum Road Course Lap times V.4
The Ridge Motorsports Park: 1.49.76
E46 M3 (AP 9668 355mm, Stock rear, Raybestos ST43 Pads, MCS 2WR, Toyo RR 295/30/18 with 18x10.5, 3020lbs with driver, aero, I/H/E/T, 326whp 4.10 Wavetrac Diff, Lowe Group Racing Setup)
Pacific Raceways: 1:33.26
E46 M3 (AP 9668 355mm, Stock rear, Raybestos ST43 Pads, MCS 2WR, Hankook TD 295/30/18 with 18x10.5, 3020lbs with driver, aero, I/H/E/T, 326whp, Lowe Group Racing Setup)
Jump to top flyweight is offline   Reply With Quote
Old Thu, Jan-10-2019, 09:41:42 PM   #22
nholmes
Track Junky
nholmes's Avatar
Car: E36 M3
Track: Thunderhill Raceway East Bypass
Best Lap Time: 2:08.58
Brakes: OEM Calipers, Endless N35S Pads, ATE Super Blue
Suspension: MCS 1-Way Coilovers
Tire: Nitto NT01
Other Mods: See video description
Weight w/driver: 3160
Notes: First time back in two years and first time with this car
Car: E36 M3
Track: Buttonwillow Raceway Park
Configuration: CW13
Best Lap Time: 2:05.85
Brakes: OEM Calipers, G-loc R12 pads, ATE Super Blue
Tire: Nitto NT01
Weight w/driver: 3118
Notes:
2:05.85 nholmes E36 M3 (G-Loc R12, MCS 1 way 600/700, NT01's, 3118lbs w/driver)
Check out my build!
Old Fri, Jan-11-2019, 01:55:51 AM   #23
Kwakjoe
Kwakjoe's Avatar
Updated. Gents, moving forward, please try to use the format I provided in the first post and thank you to those you are.
Old Sat, Jan-12-2019, 01:48:30 PM   #24
Sirenty
Sirenty's Avatar
Reputation: 0 Sirenty has disabled reputation
Summit Point
1:25.22 Sirenty E46 M3 (sick engine), 288/280 cams, SSV1, NT01, 3.91 diff, PFC z45, PFC08, Ohlins R&T
Money shifted my car at WG the first day (spun to 9300) but still finished the weekend because we thought itd be fine due to how the engine was built. Did SP the next weekend, where I recorded this time and was on pace for a 24.x when I ultimately pitted in halfway through the third session and left due to the car consuming a quart of oil per session and some worry it was going to blow again.
After tear down, found half the valves bent, rods stretched, and messed up harmonic balancer. Rebuilt the engine (again) and looking forward to what it can do this year.
Jump to top Sirenty is offline   Reply With Quote
Old Sat, Jan-12-2019, 01:54:54 PM   #25
ThunderMoose
Originally Posted by Sirenty View Post
Summit Point
I spun to 10,200 at WGI in 2016. Made it two years before I ended up spinning two bearings - not sure if related.
Old Sun, Jan-13-2019, 12:45:22 AM   #26
Sirenty
Sirenty's Avatar
I did the exact same misshift (tracking out in right hander, try to shift from 3rd to 4th, 4th blocked, try to force it instead of calming down, touch 2nd) in the first session at VIR earlier in the year and finished the weekend. It was with Chin so a ton of track time.
Couple weeks later, first session at SP, braking for turn 1, piston disintegrated and blew a hole in the block...
I always thought these were instant engine failure types of events but apparently they can keep ticking for quite a while.
Old Tue, Jan-15-2019, 04:52:58 AM   #27
jimmypet
Reputation: 0 jimmypet is on a distinguished road
All these lists seemed to underpopulated by 30 year old E30M3s LOL.
I dont visit this site too often, but I have enjoyed paging through the past thread and this one looking at the lap times (at least Northeast ones I can relate to).
Some really fast cars / drivers on here. Not to single anyone out, but Thundermoose you have put down some stinking fast times.
I dont know if these are my best times ever, but they are from most recent seasons race laps that I could find on the SCCA NEDiv results page (they dont post qualifying results and I dont remember all of them LOL) They are pretty good indicators.
Hopefully I have configured these correct for this thread.
Summit Point Main
(1:23.035) (jimmypet) (E30M3) (SCCA Production SPU - 2.3, 11:1, AlphaN, T5 trans, Grp N suspension, Wilwood brakes, 245/580-15 Hoosier Radials Gutted, full cage)
Watkins Glen (SHORT / NASCAR)
(1:23.917) (Jimmypet) (E30M3) (SCCA Production SPU - 2.3, 11:1, AlphaN, T5 trans, Grp N suspension, Wilwood brakes, 245/580-15 Hoosier Radials Gutted, full cage)
Watkins Glen (Long / Boot)
(2:08.543 ) (Jimmypet) (E30M3) (SCCA Production SPU - 2.3, 11:1, AlphaN, T5 trans, Grp N suspension, Wilwood brakes, 245/580-15 Hoosier Radials Gutted, full cage)
Pittsburgh International
(1:56.781) (Jimmypet) (E30M3) (SCCA Production SPU - 2.3, 11:1, AlphaN, T5 trans, Grp N suspension, Wilwood brakes, 245/580-15 Hoosier Radials Gutted, full cage)
NJMP - Thunderbolt (chicane)
(1:36.167 ) ((Jimmypet) (E30M3) (SCCA Production SPU - 2.3, 11:1, AlphaN, T5 trans, Grp N suspension, Wilwood brakes, 245/580-15 Hoosier Radials Gutted, full cage)
NJMP - Thunderbolt (no chicane)
(1:34.322) (Jimmypet) (E30M3) (SCCA Production SPU - 2.3, 11:1, AlphaN, T5 trans, Grp N suspension, Wilwood brakes, 245/580-15 Hoosier Radials Gutted, full cage)
VIR
(2:12.914) (Jimmypet) (E30M3) (SCCA Production SPU - 2.3, 11:1, AlphaN, T5 trans, Grp N suspension, Wilwood brakes, 245/580-15 Hoosier Radials Gutted, full cage)
Jimmy P.
88 E30 M3 Zinnoberot - Garage Queen
88 E30 M3 Lachsilber - SCCA SPU
87 E30 M3 Prodrive British Touring Car
92 E30 MTech Cabrio - S14 Powered
98 318Ti Base M44, 5 speed
04 325i Touring - Alpine w/ Sport Package
04 Ford F350 - V10 tow machine
Jump to top jimmypet is offline   Reply With Quote
Old Wed, Jan-16-2019, 07:25:22 PM   #28
MaynardZed
MaynardZed's Avatar
Reputation: 0 MaynardZed is on a distinguished road
few new PB's
Arizona Motorsports Park
1:48.037 MaynardZed E36 M3 (GC, PFC, C51, 2814lbs w/driver)
Arizona Motorsports Park CCW
1:48.893 MaynardZed E36 M3 (GC, PFC, C51, 2814lbs w/driver)
Wild Horse Pass East
1:03.203 MaynardZed E36M3 (GC, PFC, C51, 2814lbs w/driver)
Thank you KwakJoe for taking over the board. I know first hand how much of a pain in the rear it can be because I do the track records board for the newer M3/4's. Even have M2 and a few others trying to sneak their times in on my board. I don't even have the M4 anymore, traded it in for a Porsche and I still maintain the board, lol!
It is SOOO much easier to maintain a board like this if everyone puts their entry on one line like I did in this post so all that KwakJoe needs to do is copy and paste the line onto the main post. When people put a post up that has the times, track, etc. all random it needs to be done manually and can be really tedious. Plus the line doesn't need to be a long dissertation of mods.
1999 BMW E36 M3 Race Car
Ground Control Race Suspension
Full Cage - Flatout Motorworks
OMP Full Containment Race Seat
S52 with bolt ons 237 rwhp (DynoJet)
2510lbs
ProAutoSports PS2 champion 2016, 2017
ProAutoSports TT champion 2014, 2015, 2018
Jump to top MaynardZed is offline   Reply With Quote
Old Sun, Jan-20-2019, 05:09:02 PM   #29
ruffy dongles
Reputation: 0 ruffy dongles is on a distinguished road
New PBs, I'll edit the post to add video for Laguna lap when I get around to it:
Laguna Seca
1:44.51 - ruffy dongles- E46 M3 - AP BBK, TCK SA, 275 RE71R, 304 whp, 3600 lbs (w/ driver)
Sonoma
1:57.88 - ruffy dongles- E46 M3 - AP BBK, TCK SA, 275 RE71R, 304 whp, 3600 lbs (w driver)
Originally Posted by MaynardZed View Post
It is SOOO much easier to maintain a board like this if everyone puts their entry on one line like I did in this post.
Include weight
IG @mannschaftschnell
Jump to top ruffy dongles is offline   Reply With Quote
Old Sun, Jan-20-2019, 06:42:59 PM   #30
ruffy dongles
Nice! Never seen the window and door switches on dash like that. 4.10 seems to really suit Ridge? Always like seeing the scenic tracks in PNW..
Discussing M3Forum Road Course Lap times V.4 in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
