Old Tue, Jun-18-2019, 03:17:37 AM   #491
nholmes
Track Junky
nholmes's Avatar
Default Re: 1998 E36 M3 Dakar HPDE Car - Picture Intensive
Originally Posted by Nugs View Post
Good progress.
Do you have more info on the Aluminium and plastic bumper parts?
Hey!
RockAuto sells plastic versions of the OEM crash beam. Itís like $65 shipped?
You can get the bumper brackets here:
https://elianmotorsport.com/collecti...ooks-pre-order
Check out my build!
Old Tue, Jun-18-2019, 11:31:52 PM   #492
Nugs
Reputation: 0 Nugs is on a distinguished road
Thanks mate
Jump to top Nugs is offline   Reply With Quote
Old Wed, Jun-19-2019, 01:31:31 AM   #493
DrftKingIII
VSCERL
DrftKingIII's Avatar
Reputation: 0 DrftKingIII is on a distinguished road
Originally Posted by nholmes View Post
I've decided to remove my brake ducting. I've read a lot of anecdotal evidence that the rapid cooling of the rotor caused by ambient air being blown into the center vanes of the rotor is speeding up the process of failure. A rotor only has so many heat cycles before it fails completely. The ducting is accelerating this process since it does not allow for the rotors to cool gradually while the car is sitting. That being said, we'll see how these new rotors I've ordered from Coleman do. I think this would be a true test if I was using OEM rotors, but I'm comfortable enough to just do this either way.
I was just thinking about this today as I'm planning to refresh my brakes. Do you have any temperature paint on the rotors or calipers?
When's your next track day? I'm interested to see how this pans out.
Past: '99 Hellrot/Dove M3/2/5 | '97 S14 1JZ | '06 Triumph Daytona 675 | '01 330I M-Tech I | Current: '96 Estoril/Black M3/2/5
Jump to top DrftKingIII is offline   Reply With Quote
Old Wed, Jun-19-2019, 04:16:27 PM   #494
nholmes
Track Junky
nholmes's Avatar
I do. I'll put some on these rings once I get them next week.
Right now it's looking like 7/28. I'll post in here if you want to subscribe.
Check out my build!
Old Mon, Jun-24-2019, 05:03:04 PM   #495
nholmes
Track Junky
nholmes's Avatar
New rotor rings arrived on Friday so I slapped them on.
Next event is 7/28 so there's time to finish this PCV replace as well.
Looking into some relatively high oil consumption. Starting with the cheap an easy first, the PCV.
Green to White @ 806*F
Orange to White @ 1040*F
Red to White @ 1130*F
Check out my build!
Old Wed, Jul-10-2019, 04:36:52 PM   #496
nholmes
Track Junky
nholmes's Avatar
Crank case separator came in and is installed.
Tossed some caliper temp stickers on the fronts as part of my data collection regarding cracked rotors and ducting.
Check out my build!
Old Fri, Jul-12-2019, 04:38:08 PM   #497
nholmes
Track Junky
nholmes's Avatar
Added temp stickers to my rear calipers and AP Racing temperature paint to my rear rotors.
Check out my build!
Discussing 1998 E36 M3 Dakar HPDE Car - Picture Intensive in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
