Old Tue, Oct-25-2016, 06:15:55 PM   #41
BandarM3
49ers Faithful
BandarM3's Avatar
Reputation: 0 BandarM3 is on a distinguished road
Default Re: 1998 E36 M3 Dakar HPDE Car - Picture Intensive
Fantastic build! Very clean evo and integra!!
Jump to top BandarM3 is offline   Reply With Quote
Old Wed, Oct-26-2016, 09:29:18 PM   #42
nholmes
Track Junky
nholmes's Avatar
Small update here:
My steel transmission bracket arrived. Still on the fence regarding which shifter I plan to run (OEM vs CAE) but if I go CAE, I need solid mounts and then a steel bracket to prevent the OEM one from giving up the ghost.
Bearing puller showed up:
Look at all that funk:
Nice and clean! Giggity giggity!
New F.A.G. pilot bearing installed, best Korea has to offer!
Check out my build!
Jump to top nholmes is online now   Reply With Quote
Old Fri, Oct-28-2016, 07:04:33 PM   #43
W///
W///'s Avatar
Reputation: 0 W/// is on a distinguished road
Thailand
Really great thread. I've got an E36 and E92 M3 combo myself, and they're both great cars. No plans to ever get rid of either. The handling of the E36 is magic, but as you said, the E92's engine is just something truly special.
Keep the updates coming!
Current: E92 M3 Sparkling Graphite/Bamboo Beige/6MT. E36 M3 Techno Violet/Dove/5MT. E85 Z4MR Alpine White/Imola Red/6MT.
Build Journal
Jump to top W/// is offline   Reply With Quote
Old Sun, Oct-30-2016, 01:10:51 AM   #44
JitteryJoe
Great job! Pilot bearing is gross.
What did you decide to do about that rear engine seal? Looks pretty oily. Or is transmission oil all over it?
Did you get the tran brace from Rally Road?
Good luck!
Old Sun, Oct-30-2016, 06:43:32 AM   #45
nholmes
Track Junky
nholmes's Avatar
Good luck!
There was a lot of sludge in there!
I've got a rear main seal on the way.
You are correct, that brace is in fact from Rally Road.
Cleaned up the bell housing tonight:
Check out my build!
Old Mon, Oct-31-2016, 05:02:24 PM   #46
nholmes
Track Junky
nholmes's Avatar
Got my baffled pan back from its acid bath:
Check out my build!
Old Mon, Oct-31-2016, 10:26:47 PM   #47
Evtron
Evtron's Avatar
Reputation: 0 Evtron is on a distinguished road
Very nice! How did you clean the oil pan? Looks good.
E36 M3 Sedan Journal
Jump to top Evtron is offline   Reply With Quote
Old Mon, Oct-31-2016, 10:45:58 PM   #48
nholmes
Track Junky
nholmes's Avatar
Got a buddy that works at a local dealership. I drop parts off with him from time to time to soak in their tank.
Check out my build!
Old Thu, Nov-03-2016, 04:38:53 PM   #49
nholmes
Track Junky
nholmes's Avatar
So I finally got all of my bushings out and pins, just waiting on my replacement stuff for the shift selector to arrive.
The top three were super easy, but 5th and reverse on my transmission (1998 w/ 183,000 miles) were basically fused in the bushings.
I first started with trying to use a screw to get 5th out, but that only got the screw buried deep in there. Getting a new pair of needle nose long enough to reach it was a surprise expense. Bonus: Now I have another tool.
I then tried using 3/8 drop anchors, which worked to get the 5th pin out, but wasn't going to work on the bushing.
Thanks to this thread renting the blind bushing puller is major key.
http://www.m3forum.net/m3forum/showthread.php?t=398477
One pro tip: When expanding the puller to remove the bushing, I found that it's really easy to over do it and then drag the tool along the inside of the steel sleeve, scoring it in the process. This, of course, now left metal shavings inside the transmission. I got as many out as I could with Q-tips, but I'm sure some will be floating around inside the transmission. Looks like a fill and drain will be in order after the car is buttoned back up and driven for a couple miles.
Some pictures of the "fun" for those interested:
You get creative when you start to get pissed off. Here I tried to use 3/8 drop anchors to get out the 5th gear pin. It worked, but was a pain in the ass:
Blind bushing pulled used to great success:
Tools sacrificed to the automotive gods during this project:
My messy ass work area as I fought with these pins for three days now:
Check out my build!
Old Thu, Nov-03-2016, 05:02:37 PM   #50
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
Nice, I remember doing those on the 330i. The drifts are also really helpful, as well as that puller, as you found out.
Discussing 1998 E36 M3 Dakar HPDE Car - Picture Intensive in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
