Old Fri, Oct-21-2016, 11:27:08 PM   #31
nholmes
Track Junky
nholmes's Avatar
Default Re: 1998 E36 M3 Dakar HPDE Car - Picture Intensive
Originally Posted by Evtron View Post
I think you're in good company here.
Except for the plasti-dip. But that's just me. Keep it up man.
Awesome.
Yeah, as far as appearance goes I don't think there's any accounting for variances in taste.
Eye of the beholder and all that.
Check out my build!
Old Mon, Oct-24-2016, 11:29:51 PM   #32
nholmes
Track Junky
nholmes's Avatar
My Sullivan Race Pedals arrived. Very high quality track pedals that come in different grip patterns and with option anodizing.
Ran these in my track evo with much success. Went with black this time around for a more subdued look inside the car.
Finally got the transmission out:
Then started to work my way in towards the pilot bearing and the rear main seal:
Lots of sludge in the transmission from what I assume is a leaking rear main seal:
Spring clip is busted:
Looks like someone installed a SACHS clutch and pressure plate from an E28 M5 to avoid the need for a dual mass flywheel:
Check out my build!
Old Tue, Oct-25-2016, 02:45:12 AM   #33
JitteryJoe
Good luck with the rear engine seal. Replaced mine a couple years ago when I did the clutch. Getting the seal seated was a bit of an effort. I removed the carrier. Some folks replace the seal with the carrier in place. Could not see how you can get it seated properly that way.
I see more of those Harbor Freight trans jacks in different threads . They must have sold them like crazy. Handy though. Have one myself.
Old Tue, Oct-25-2016, 06:22:15 AM   #34
nholmes
Track Junky
nholmes's Avatar
Thanks for the heads-up!
I'm planning on following this as close as possible:
http://workshop-manuals.com/bmw/3_se...mission_side)/
Co-worker has one, he was nice enough to loan it to me for as long as I need.
Check out my build!
Old Tue, Oct-25-2016, 04:24:27 PM   #35
usedunderwear
Reputation: 0 usedunderwear is on a distinguished road
While you have the transmission out, probably should do the detent pins?
Jump to top usedunderwear is offline   Reply With Quote
Old Tue, Oct-25-2016, 04:49:20 PM   #36
nholmes
Track Junky
nholmes's Avatar
Absolutely. I don't want to money shift on track and have my valve train eat itself.
Check out the 5th gear gangsta lean:
Straight up and down:
Gangsta:
Check out my build!
Old Tue, Oct-25-2016, 05:25:15 PM   #37
JitteryJoe
You'll need these parts & tools.
http://thayermotorsports.com/collections/transmission
Getting the two sleeves out is a PITA (2 of the 5 pins serviced).
Damaging the sidewall is very easy to do.
Old Tue, Oct-25-2016, 05:45:20 PM   #38
nholmes
Track Junky
nholmes's Avatar
Thanks for that.
I was going to use this guide:
http://webspace.ringling.edu/~dplass...hift_pins.html
Check out my build!
Old Tue, Oct-25-2016, 06:54:22 PM   #39
JitteryJoe
Thanks for that.
Yup, that is the guide. Step 5 is the difficult one. You have to carefully wedge at the seam of the insert and bend it inward so you can get something to grip it. Some people use a blind hole puller but I could never get that method to work. Randy Forbes uses a screwdriver where he ground the end to be cup shaped so he can wedge under the seam without damaging the sidewall. Pretty neat trick.
Old Tue, Oct-25-2016, 07:07:43 PM   #40
nholmes
Track Junky
nholmes's Avatar
Not looking forward to it.
Check out my build!
Discussing 1998 E36 M3 Dakar HPDE Car - Picture Intensive in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
