Old Mon, Jun-17-2019, 04:20:27 PM   #11
SMG cog light
Default Re: Smg pump rebuild
Good job. To all of those that have reconditioned their pumps, can you provide live data of the hydraulic pressure decay? I am collecting data from as many people as I can to compare the data. This will help other people that are still experiencing issues even with new components on their HCU.
Jump to top SMG cog light is offline   Reply With Quote
Old Mon, Jun-17-2019, 11:46:34 PM   #12
Mel279
Reputation: 0 Mel279 is on a distinguished road
Brunei
My present pump in the car having issue with a fault code P1715 (hydraulic pressure loss in system). The pump had almost new accumulator and also new Burkhart motor so I suspect the internal seals are leaking. I've done the resistor mod which I thought was the issue but the culprit turn out to be the oil pressure issue. The car would goes in neutral while driving and at the same time the engine stall.
Jump to top Mel279 is offline   Reply With Quote
Old Mon, Jul-01-2019, 12:58:57 PM   #13
Mel279
Brunei
Here some pics of my rebuild smg pump and I replace all the seals include the solenoid seals. There were 2 other seals( I replace with new silicone seal which I only have at that time) need to be replace which was on the red connector which connector to the reservoir hose.
Old Mon, Jul-01-2019, 04:08:46 PM   #14
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Smg Pump Gear Shaft Repair Seals Group Buy
http://www.m3forum.net/m3forum/showthread.php?t=608412
Discussing Smg pump rebuild in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
