Old Wed, Jul-02-2014, 09:21:17 PM   #41
06M3ZCP
06M3ZCP's Avatar
Reputation: 0 06M3ZCP is on a distinguished road
Default Re: OEM CSL MAP/IAT/FLAP Wiring
Datasheet on the H-bridge: http://cache.freescale.com/files/ana...et/MC33186.pdf
It's the same one used to operate the throttle actuator.
The flap is always open or close, but that's only because BMW programmed it that way. They could have made it operate more like a throttle body if they chose to do so.
Thank you Terra. BTW I did have that info on the Freescale chip (from you on a PM). Much appreciated. My question is kinda OT anyway because my implementation is a bit different.
Journal:
http://www.m3forum.net/m3forum/showthread.php?t=597241
Previous:
http://www.m3forum.net/m3forum/showthread.php?t=457440]
2006 AW/IR ZCP 6MT
OEM CSL Muffler, OEM CSL Console, Redish Plates TIG/rosette + wheel arch, Full Besian, Stoptech BBK. short shift kit
Jump to top 06M3ZCP is offline   Reply With Quote
Old Sat, Jul-05-2014, 01:53:44 PM   #42
Bigfoot
Reputation: 0 Bigfoot is on a distinguished road
United Kingdom
Hi Ejaz.
Awesome thread, as always, mate and you've got my attention.
My car presently has CSL headers, OE CSL airbox complete with unused brand new flap & motor and MSS54HP DME so this could be a very interesting mod.
I'm not sure if anyone has done this over here in the UK so information regarding modifying the DME to include the bridge and loading OE CSL maps may not be readily available.
Do keep us posted fella.
Jump to top Bigfoot is offline   Reply With Quote
Old Sat, Jul-05-2014, 03:20:57 PM   #43
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Originally Posted by Bigfoot View Post
Hi Ejaz.
Mate this is easily possible. You have all the right parts. Let me know if you need help with it and it's easy to get sorted.
Old Sun, Jul-06-2014, 05:21:36 AM   #44
TuningTechFS
TuningTechFS's Avatar
Reputation: 0 TuningTechFS is on a distinguished road
0-60 you and Terra are always keeping things positive and supporting our community.
Jump to top TuningTechFS is offline   Reply With Quote
Old Sun, Jul-06-2014, 07:13:01 AM   #45
0-60Motorsports
Bahrain
Cheers Frank and happy 4th of July.
Old Tue, Jul-08-2014, 05:52:03 AM   #46
So I was poking around with my multimeter a bit, and it looks like X60003/Pin 16 and X60004/Pin 35 are both unused grounds on the MSS5x -- I think it'd be easier to just use those points rather than splice
I haven't found any unused +5v sources though, so some splicing is still necessary
So this is my plan of attack:
Map Sensor:
Pin 1 -> X60003/Pin 7 (tap into bundle inside wire box)
Pin 2 -> X60003/Pin 16 (Ground)
Pin 3 -> X60003/Pin 18 (Signal)
IAT:
Pin 1 -> X60003/Pin 22 (Signal)
Pin 2 -> X60004/Pin 35 (Ground)
Flap Position Sensor:
Pin 1 -> X60003/Pin 17 (Ground -- Reuse MAF wire)
Pin 2 -> X60003/Pin 1 (Signal -- Reuse MAF wire)
Pin 3 -> X60003/Pin 7 (+5V -- Reuse MAF wire)
Flap Actuator:
Pin 1 -> X60002/Pin 8
Pin 2 -> X60002/Pin 9
This way you do minimal splicing. I'm reusing the MAF wires for the flap position sensor since it's in the right location and uses SLK contacts like the flap position connector (so shouldn't even have to recrimp).
Last edited by terraphantm; Tue, Oct-07-2014 at 12:57:50 AM. Reason: removed bad info
Old Tue, Jul-08-2014, 07:21:33 AM   #47
0-60Motorsports
Bahrain
Map Sensor:
Pin 1 -> X60002/Pin 17 (tap into bundle inside wire box)
IAT:
Flap Actuator:
Pin 1 -> X60003/Pin 8
Pin 2 -> X60003/Pin 9
Yeah we saw that too, I just wanted everything to go in the way BMW did it on the CSL
So the Map wiring is actually routed through the ignition coils harness?
Last edited by terraphantm; Fri, Jul-11-2014 at 07:23:29 AM. Reason: Removed bad info
Old Tue, Jul-08-2014, 07:25:51 AM   #48
Bigfoot
United Kingdom
Map Sensor:
IAT:
Flap Actuator:
Amazing work Terra. I cringed at the thought of splicing/cutting my wiring loom and was even looking at buying an OEM loom to ease my conscience.
Could you please expand on SLK contacts. I've googled it without success.
Many thanks for your continued input.
Last edited by terraphantm; Fri, Jul-11-2014 at 07:24:00 AM. Reason: Removed bad info
Old Tue, Jul-08-2014, 07:30:27 AM   #49
On a real CSL, it looks like it's routed through the injector harness. I'm probably going to run it across the back of the engine into the DME box though, at least for now.
Old Tue, Jul-08-2014, 07:32:54 AM   #50
0-60Motorsports
Bahrain
Thats the way i've done it too and now that its done I cant be bothered to change it.
Discussing OEM CSL MAP/IAT/FLAP Wiring in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
