Old Sat, Jun-28-2014, 03:25:42 AM   #21
SliM3
SliM3's Avatar
Default Re: OEM CSL MAP/IAT/FLAP Wiring
0-60,
Would you mind telling me what the diameter of the airbox inlet, or flap, is?
Old Sat, Jun-28-2014, 05:33:25 AM   #22
Originally Posted by 0-60Motorsports View Post
Thanks Brother. I already have the boots etc. Just need the map connector cover. Actually as I have an actual CSL in the shop let me see if i can get the part number for the map cover from that
We might be SOL on the map cover. N54 uses the same part for the camshaft position sensor, so I took a look at that. The part number on there is 7511984, but that doesn't show up in the catalog.
Not a terrible loss, it's a cosmetic piece.
Edit 2: http://www.cslregister.com/forum/sho...35&postcount=4 It is indeed 7511984 on the real CSL too. Part number doesn't pull up anywhere, even if you type in the prefix as well (1252).
Old Sat, Jun-28-2014, 06:05:35 AM   #23
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Originally Posted by SliM3 View Post
0-60,
Sure, Im going to the shop in a little bit. Will measure and post up for you.
Damn it. Oh well Time to look through the scrap motors etc lying at the shop.
Old Sat, Jun-28-2014, 06:14:55 AM   #24
Yeah I'm going to try the cover for the alternator connector, and if that doesn't fit I'm just going to let it go. The connector won't be visible when installed on the sensor, that area doesn't really get dirty, and the rubber grommets in the pin will keep it water tight.
...Well maybe I'll steal it from my dad's 535 if he ever decides to trade the car
Old Sat, Jun-28-2014, 06:19:22 AM   #25
0-60Motorsports
Bahrain
LOL if I find more than one Ill send you one with my MSS54.
Old Sat, Jun-28-2014, 09:03:42 PM   #26
Here's how to crimp contacts onto wire. I prefer to do this in order to avoid soldering (I don't like soldered connections in vehicle harnesses)
The contact I'm using is a little different than what most of the BMW connectors use, but the same principles apply.
You will need a crimping tool. These range from very cheap to very expensive. The expensive ones are usually the ratcheting sort that get perfect crimps every time with minimal effort. Not really necessary unless you're doing this day in and day out.
I use this one which I got for $30 on Amazon. Just search for "Weatherpack Crimper" on Amazon
First if your contacts came on a reel, cut away a single piece like so. Note how there's a small tab protruding at the end -- that is intentional, don't cut that away.
Now get your wire and strip away some insulation like so:
Next, insert the wire into the sealing grommet:
Now align the grommet and wire in the contact like so, and trim the copper strands such that they just barely extend past the front wings on the contact. Don't have to be too precise, just don't want the wires to be sticking out or not making complete contact
Now select the appropriate hole in the crimper and insert the front part of the contact and wire into it. In this case I used #2. The base of the contact should sit on the rounded part, and the two wings should face the part with a point. Now start squeezing the crimpers, and make sure the contact stays straight as it comes together. Squeeze the grips pretty tight and let go.
Repeat for the wings around the boot, except use the rounded holes (no point).
Final product should look like this, which you can insert into the connector like the premade wire/contacts from BMW.
Process for unsealed contacts is basically the same, except there's no rubber boot. Instead, the back two wings are crimped on the wire insulation itself. The crimper I posted above doesn't have a small enough rounded hole for those, so you'll have to get a little creative (or buy a different crimper). One of the pliers I have is perfect for it, but I have no idea who makes it (old toolset that my dad gave me)
Old Sun, Jun-29-2014, 12:17:14 AM   #27
0-60Motorsports
Bahrain
^Excellent tip bro. Thanks for posting that.
Old Wed, Jul-02-2014, 02:22:44 PM   #28
06M3ZCP
06M3ZCP's Avatar
Reputation: 0 06M3ZCP is on a distinguished road
Thanks for the info guys. My flap is in the open position for now until everything is sorted with the car.
By the way some of the questions I'm running into that if anyone can point me in the right direction would be much appreciated: What are the Input Signals to the H Bridge -- Continuous? Pulse? Amplitude, duration? In opening the flap I would imagine the input signal(s) are not a permanent H L otherwise the motor would always be running.
Is it fully open or closed or does the flap assume partially closed and open using the position sensor?
Journal:
http://www.m3forum.net/m3forum/showthread.php?t=597241
Previous:
http://www.m3forum.net/m3forum/showthread.php?t=457440]
2006 AW/IR ZCP 6MT
OEM CSL Muffler, OEM CSL Console, Redish Plates TIG/rosette + wheel arch, Full Besian, Stoptech BBK. short shift kit
Jump to top 06M3ZCP is offline   Reply With Quote
Old Wed, Jul-02-2014, 05:07:54 PM   #29
Datasheet on the H-bridge: http://cache.freescale.com/files/ana...et/MC33186.pdf
It's the same one used to operate the throttle actuator.
The flap is always open or close, but that's only because BMW programmed it that way. They could have made it operate more like a throttle body if they chose to do so.
Old Wed, Jul-02-2014, 05:20:46 PM   #30
0-60Motorsports
Bahrain
Terra, have you looked into tuning the flap to open earlier in non sport mode?
Discussing OEM CSL MAP/IAT/FLAP Wiring in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
