Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > M3Forum Sponsors
M3Forum Sponsors Listing of our current Sponsors
Old Sat, Jan-05-2008, 01:45:04 AM   #21
F M 3
F M 3's Avatar
Reputation: 0 F M 3 is on a distinguished road
just ordered my nav system with a few goodies.. looking forward to installing it soon...
2006 Carbon Black SMG
2006 Suzuki M109R
1997 SAAB 900SE Turbo
1980 Trojan
tc kline delrin rtab, tms rear camber/control arms, tc kline strut tower mounts, P-7 Brake pedal, tms subframe kit, pss9 coil-overs, borla mid-pipe and full exhaust, k40 R.D, dash mounted garmin nuvi 680, stage 1 afe CAI, painted side markers, key delete, dice ipod kit
Jump to top F M 3 is offline   Reply With Quote
Old Sat, Jan-05-2008, 02:30:48 AM   #22
tom @ eas
tom @ eas's Avatar
Reputation: 0 tom @ eas is on a distinguished road
Congrats on your new setup - I'm sure you will be more than pleased after installation. Of course, we'll be there to help every step of the way.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG FACEBOOK YOUTUBE FLICKR INSTAGRAM
Jump to top tom @ eas is offline   Reply With Quote
Old Thu, May-15-2008, 04:37:43 AM   #23
tom @ eas
tom @ eas's Avatar
Default ▀▄ eas - e2 aurora 60LED angel eye kits for BMW - coming soon!
We have seen lots of Angel Eye kits on the market in the past 5 years. Everything from seperate lightsources, CCFL tubes, failing inverters and LED kits with gaps and warranty issues with vendors. What happens when you can't find something for your BMW on the market that suits your needs?
You simply design them yourself.
Introducing aurora, an entirely redesigned angel eye kit for your BMW from eas - unlike anything else on the market.
aurora produces a fully uniform look using a 60 LED array, which matches most Xenon maps for an OEM look and are very bright - these can even be seen in daytime. You will immediately know another vehicle with a set after yours are installed.
Appearance
A light-emitting diode, usually called an LED, is a semiconductor diode that emits incoherent narrow-spectrum light when electrically biased in the forward direction of the p-n junction, as in the common LED circuit. This effect is a form of electroluminescence. A LED is usually a small area light source, often with extra optics added to the chip that shapes its radiation pattern. LEDs are often used as small indicator lights on electronic devices and increasingly in higher power applications such as flashlights and area lighting.
Comparison photo of Orion (left) vs. aurora (right). No "pearl necklace" or "burnt out Christmas light" syndrome here. aurora emits its light from a 60 LED array for a uniform and finished look.
2-Stage Ring Clipping mechanisms
For years, angel eye users have been plagued by clips that simply do not fit correctly - we have a solution. Our 2-stage replaceable clips allow secure clipping onto your headlight housings without the need for "spacing" or guessing alignment, especially for those with adaptive headlamps. Simply clip into place and rest assured your rings will be sure without the need for gluing or falling off from road vibration or adaptive headlight movement.
If clips are ever broken, replacements are available without replacing an entire kit.
OEM Look
aurora halos feature a sleeved highly polished ring around the circuit board, giving a thicker OEM look when on or off. Since LEDs are directional, there is no "bleedoff" in light direction allowing for maximum light output facing forward.
Safety
A Heavy duty wiring harness is included to make installation quick and painless, while adding safety to your install. No light boxes or lamp sources are used unlike older kits. Installation takes about 1 hour and will be one of the favorite mods on your BMW.
Brightest Angel Eye rings on the market
aurora Angel eyes can be seen from well over 150 feet away in pure daylight - they are BRIGHT. Using high-powered LED technology, these are the brightest on the market. With a highly polished ring engineered to emulate the OEM ring when not lit, these will look as if your BMW were equipped with Angel Eyes from factory. Kits are engineered using high quality components and are rated at over 100,000 hours or 10 years of continuous illumination.
Remote feature
aurora angel eyes feature a remote feature that will automatically dim the rings when you enter or leave the vehicle. Unlocking the vehicle will emit a "fade in" and will fade out when the vehicle is locked or if left dormant for over 15 minutes to prevent battery drainage.
LIFETIME Guarantee
There's nothing worse than having a kit that will not work, for those that have purchased other kits elsewhere and have dealt with frustrating return processed or no warranty at all, we feel your pain. eas backs up all aurora angel eye kits with a limited lifetime warranty, making this the first and last set you will purchase for your BMW. if you should ever experience a problem with your kit, we will be there to help.
Preorder today or sign up on our waiting list to be notified when orders are shipping.
e2 - aurora 60 LED Angel Eye Kit (most BMWs)
http://www.europeanautosource.com/pr...oducts_id=1883
Features
- OEM like modern look, simply the brightest kit on the market
- 60 high powered LED array for maximum brightness, withstanding shocks, vibrations, frequent switching and extreme temperatures.
- CAD designed polycarbonate ring with UV protection and additional clearance for all headlight housings
- No dangerous light boxes or heat fixtures to mount, keeping safety and cleanliness underneath your hood
- No "cold weather" start problems
- Instant transformation to appearance of vehicle after installation
- 100,000+ hour life (over ten years)
- Easy installation
- Compatible with Halogen, Xenon, Auto Leveling and Adaptive Lights
- Limited lifetime warranty
Kit Contents
- 4 Highly polished LED Halos
- 1 Heavy duty wiring harness, with remote feature
- Backed by limited lifetime warranty
- Detailed instructions
Models Supported
1999-2003 e46 3-series Coupe (pre-facelift, non-sealed lamps)
1999-2005 e46 3-series Sedan
2000-2006 e46 M3 Coupe/Convertible
1995-2001 e38 7 series
1997-2000 e39 5-series
Simply demand the best for your BMW. Available in late June from eas and authorized retailers.
Current discussion underway in this thread: http://www.m3forum.net/m3forum/showthread.php?t=211025
Old Sun, May-18-2008, 08:33:37 PM   #24
prat
Reputation: 0 prat is on a distinguished road
Why is there a $60 difference between these and OrionII?
Jump to top prat is offline   Reply With Quote
Old Mon, May-19-2008, 06:48:48 PM   #25
tom @ eas
tom @ eas's Avatar
These are not OrionIIs, but a completely different product.
Old Tue, Jul-29-2008, 09:24:47 PM   #26
bmw_mthr33
bmw_mthr33's Avatar
Reputation: 0 bmw_mthr33 is on a distinguished road
thanks again
Jump to top bmw_mthr33 is offline   Reply With Quote
Old Wed, Aug-13-2008, 06:25:57 PM   #27
lucky strike
Lucky Strike
lucky strike's Avatar
Reputation: 0 lucky strike has disabled reputation
Just ordered a DICE Ipod Silverline Kit from Jurrian. Glad I could help out a site sponser.
Thanks,
Bobby Berk
Jump to top lucky strike is offline   Reply With Quote
Old Fri, Oct-31-2008, 05:08:11 PM   #28
bmw_mthr33
bmw_mthr33's Avatar
Default wtb:screen for air hole in vcsl bumper!
someone on the forum has told me that you guy's carry a screen for the air hole on a vcsl bumper is that right if so let me know because i want to purchase it!
thanks, randy
Old Fri, Oct-31-2008, 05:48:07 PM   #29
tom @ eas
tom @ eas's Avatar
thanks, randy
Unfortunately, we do not offer this item.
Old Mon, Dec-01-2008, 08:25:10 PM   #30
Jackalope
Jackalope's Avatar
Reputation: 0 Jackalope is on a distinguished road
Hello I notice that you don't have the LED tail lights on your site anymore, are you just currently out of them for the E46 M? Or if this is an error please let me know as I'll order a set of them in smoke as well as the smoked crystal front corner lights and smoked side markers. Also are the tail lights sold as a set of 4 pieces? Tail lights and back up lights too? I see some vendors don't seel them this way while others do. Please let me know so I can order these and have them all by Christmas.
Thank you,
Terry.
P.S. do you price match as well?
Jump to top Jackalope is offline   Reply With Quote
auto, european, source
European Auto Source. Who is tending the store? bosundave E46 M3 (2001-2006) 1 Fri, Jun-27-2008 12:03:42 AM
European Auto Source 1x1 CF Trim Kit Installed !! LightWerkz Member Photos and Videos 59 Tue, Apr-08-2008 07:44:26 PM
European Auto Source M3 Carbon Fiber Mirror Covers For Sale. YellowBird330 Parts for Sale/Wanted 17 Mon, Jan-01-2007 12:15:46 AM
European Auto Show Roll In truwon Great Lakes 2 Mon, May-30-2005 07:31:40 AM
cheapest UK/European source of M3 for UK buyer? Radish E46 M3 (2001-2006) 16 Mon, Nov-03-2003 10:46:18 AM
Discussing european auto source in the M3Forum Sponsors Forum - Listing of our current Sponsors at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
