Old Sun, Apr-22-2018, 02:01:03 AM   #21
e46Dan
Reputation: 0 e46Dan is on a distinguished road
Default Re: The strangest oil leak
Originally Posted by PITT M3 RR View Post
Ok bmw calls for sealant there. That’s the first thing I would do and you can also inspect the VC for cracks. That’s something cheap and easy to cross off before going further.
Good point, it's pretty easy to pull the valve cover gasket off and add some simple insurance. I put a small bead of rtv around the surface of the head and the valve cover. I've got my fingers crossed. The gasket did get slightly bent in shipping back on the corner near the half moons.
....and still leaking. I guess the transmission is going to come off again so I can get to the back of the head.
Jump to top e46Dan is offline   Reply With Quote
Old Sun, Apr-22-2018, 02:40:10 PM   #22
e46Dan
At this point I think it was the intake cam sensor. I replaced the o-ring and took it for a drive. There was just a smidge of oil this time and I believe it was old oil that worked its way down when it got hot.
Old Sun, Apr-22-2018, 02:51:05 PM   #23
PITT M3 RR
PA
PITT M3 RR's Avatar
That makes sense. Especially w the angle of the motor. Clean it all up real good and test again. Nice find.
S54 E36 BUILD
Old Sun, Apr-22-2018, 04:51:36 PM   #24
mrgizmo04
mrgizmo04's Avatar
When I was chasing this crap, carb cleaner and paper towels were my friend. I went through several cans of carb cleaner at once to really clean everything up and figure out where it was coming from.
Good progress.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sun, Apr-22-2018, 06:08:06 PM   #25
Filipebmwm3
M3 power
Filipebmwm3's Avatar
Reputation: 0 Filipebmwm3 is on a distinguished road
To reach that sensor u have to remove the cabine filter and all parts that included?? I know that place in the back of the engine is a pain in the but to reach...
Jump to top Filipebmwm3 is offline   Reply With Quote
Old Sun, Apr-22-2018, 06:14:52 PM   #26
e46Dan
I removed the cabin filter and my intake manifold. Then I removed the vacuum rail next to the injectors and the plastic triangular piece that sits at the end of the rail in front of the sensor. Thankfully I don't usually have the cabin filter in and my intake manifold is super easy to remove.
Old Sun, Apr-22-2018, 06:18:44 PM   #27
mrgizmo04
mrgizmo04's Avatar
Couple of diys with pics. Intake side is a bit of a pain.
http://www.e46fanatics.com/forum/sho.../topics/862891
https://www.pelicanparts.com/techart...eplacement.htm
'05 M3 6MT coupe
Old Mon, Apr-23-2018, 01:21:59 PM   #28
e46Dan
I was able to pull my hand back there and it was dry except for where the bolt holds it to the block. You might try that before you take it all apart. I've put about 20 miles on the car now and no more leaks.
Old Tue, Apr-24-2018, 03:43:07 AM   #29
cloudm3
cloudm3's Avatar
Reputation: 0 cloudm3 is on a distinguished road
Did you check the cpv? I had a similar leak and when put on a lift, the shop determined leak was from the cpv
Jump to top cloudm3 is online now   Reply With Quote
Old Tue, Apr-24-2018, 03:45:58 AM   #30
mrgizmo04
mrgizmo04's Avatar
Post 3 from OP rules it out...
'05 M3 6MT coupe
Discussing The strangest oil leak in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
