Old Sat, Apr-21-2018, 02:02:24 AM   #11
e46Dan
Reputation: 0 e46Dan is on a distinguished road
Default Re: The strangest oil leak
Not easy to get back behind the head
Jump to top e46Dan is offline   Reply With Quote
Old Sat, Apr-21-2018, 02:25:38 AM   #12
PITT M3 RR
PA
PITT M3 RR's Avatar
Not at all, I pulled the cabin filter housing and used a clean paper towel to wipe the rear. I had a decent view with the trans out.
Once you clean yours, how long does it take for the leak to “show” again ?
S54 E36 BUILD
Old Sat, Apr-21-2018, 03:28:08 AM   #13
mrgizmo04
mrgizmo04's Avatar
I don't have the thread or the pic handy, but when I was chasing what I thought was another rear main or oil pan gasket, I found I pinched an intake cam sensor wire when I put the valve cover back on after vanos work. Half moons on vcg were dry, most of the vcg was dry. Leak went down into the bellhousing on intake side of the back of the block and also snaked around the head gasket a bit toward the exhaust side and then down into the bellhousing...was a bit of a pain...
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Apr-21-2018, 03:32:25 AM   #14
e46Dan
It showed up after about 5 miles of spirited driving this last time. You can kinda see the green line in this picture where the head meets the block by the transmission bolt.It's definitely been getting worse. I'll drive it a little tomorrow until it leaks and see if I can trace it better. All the plugs are present in the back of the head though I wouldn't be surprised if it was leaking around one of the freeze plugs.
Old Sat, Apr-21-2018, 03:34:13 AM   #15
e46Dan
That's funny, I did the same where I pinched a wire from the fuel injector on the driver side. That leaked enough oil to get my attention fairly quick. The oil filter housing is next on my list of things to replace. It's seeping a little but not enough to explain the amount I'm getting on the bottom of the transmission.
Old Sat, Apr-21-2018, 01:01:37 PM   #16
Filipebmwm3
M3 power
Filipebmwm3's Avatar
Reputation: 0 Filipebmwm3 is on a distinguished road
I thought they could be the problem after reading that thread. I pulled the transmission and redid the rear main seal and casing for it.
If this image was a s54, the red marked would be where I can see the oil coming from. The good news is it's not the rear main or oil pan gasket.
Did u find out your leaking already? Because i have a similar leak on that area too!
Jump to top Filipebmwm3 is offline   Reply With Quote
Old Sat, Apr-21-2018, 02:17:48 PM   #17
e46Dan
Not yet, I need to find time to drive the car to get it leaking again. I'll post it up when I eventually solve it.
Old Sat, Apr-21-2018, 03:44:40 PM   #18
PITT M3 RR
PA
PITT M3 RR's Avatar
Real quick, is the oil at the bottom of the pan glowing too? I ask my because my slave was also leaking in my bellhousing BUT, I knew it was oil because it was glowing, it was just mixing.
I see a hint of color on the pass side of the block near where you were referring. He mentioned the pinched wire. Due to the angle of the motor, have you check anything along the driver side of head / block? Pull the intake? Oil is tricky shit.
Also did you use sealant on the moons and cover junctions?
Also I’m assuming no spatter on the back of the flywheel?
S54 E36 BUILD
Old Sat, Apr-21-2018, 03:54:27 PM   #19
e46Dan
Yeah it glows. The slave cylinder is pretty new. The car has sat for a couple days so a lot of the oil was already cleaned up when I took that picture. When it leaks there's a visible stream from that spot on the head. I need to get the uv light and borescope around the backside of the head. I didn't put any sealant in the half moons this time around but they felt dry.
Old Sat, Apr-21-2018, 05:08:54 PM   #20
PITT M3 RR
PA
PITT M3 RR's Avatar
Ok bmw calls for sealant there. That’s the first thing I would do and you can also inspect the VC for cracks. That’s something cheap and easy to cross off before going further.
S54 E36 BUILD
Discussing The strangest oil leak in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
