Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted > E36 / E30 - Parts for Sale/Wanted
E36 / E30 - Parts for Sale/Wanted Use this section to post parts for sale or wanted that are related to the E36 or E30 only.
Old Fri, Aug-04-2017, 08:54:35 PM   #1
David@ApexRaceParts
David@ApexRaceParts's Avatar
Default ► New TITEtec Wheel Locks - Extended Length Wheel Locks
TITEtec Wheel Locks
Use wheel spacers? Get wheel locks that fit. TITEtec offers the highest level of wheel security with extended length wheel locks in 2 or 4 packs to mix & match. For those who run extended stud kits, TITEtec has a solution for you as well with an open ended locking nut that fits over any length stud.
TITEtec Elite Wheel Locks are for those who require the highest level of security.
  • Available in extended lengths for use with spacers (25mm - 45mm)
  • Sold in 2 packs for front & rear fitment or 4 pack stock length
  • Free-spinning hex head that looks like an OEM bolt
  • Looks like your OEM bolts when installed
  • Unique CNC’d pattern
  • Available in M12x1.5mm
>> Shop TITEtec Elite Wheel Locks
TITEtec OEM+ Wheel Locks provide OEM quality in extended lengths.
  • Available in extended lengths for use with spacers (26mm - 48mm)
  • Sold in 2 packs for front & rear fitment or 4 packs in extended lengths
  • More secure than typical wheel locks due to free-spinning ring
  • Unlimited key patterns
  • Available in M12x1.5mm and M14x1.25mm
>> Shop TITEtec OEM+ Wheel Locks
TITEtec Stud Kit Wheel Locks are true key'ed nuts compatible with any length stud.
  • Securely locks over any extended length stud kit
  • Open-ended nut design won’t trap water in the threads and cause rust
>> Shop TITEtec Stud Kit Wheel Locks
TITEtec Slim Wheel Locks provide increased protection for wheels with small-diameter, tuner style bolt holes.
  • Available in extended lengths for use with spacers (26mm - 45mm)
  • Sold in 2 packs for front & rear fitment or 4 packs in stock length
  • Fits smaller diameter bolt holes down to 21mm
  • Available in M12x1.5mm and M14x1.25mm (4 pack/28mm only)
>> Shop TITEtec Slim Wheel Locks
Why choose TITEtec Wheel Locks?
TITEtec caters to the modified aftermarket with its product lines. All hardware is cold forged in Italy alongside the OEM hardware made for most European auto manufacturers. Call our experts at APEX Race Parts for more details (925) 245-0773.
Jump to top David@ApexRaceParts is offline
Rate Seller View Rating
Old Fri, Aug-11-2017, 11:45:19 PM   #2
ApexRaceParts
Default Re: ► New TITEtec Wheel Locks - Extended Length Wheel Locks
Check out our wheel locks with a new twist. Available in extended lengths as well as sets of 2.
TITEtec Elite shown above.
Jump to top ApexRaceParts is offline   Reply With Quote
Old Mon, Sep-18-2017, 03:03:21 AM   #3
omairtheman1
Do you have wheel locks available for 12 mm spacers? It only states 25 mm to 45 mm.
I would want one key because I do not run spacers in the rear (Conti DW rubs with the 5 mm recommended spacers).
Old Thu, Sep-21-2017, 11:11:35 PM   #4
ApexRaceParts
Thanks for the post! We sure do. For 12mm spacers, you will want to use 38mm hardware, which we offer in all styles of TITEtec locks.
In most cases, we are able to obtain sets of 2 different lengths with the same key pattern.
Hope this helps, please let us know if you have any additional questions!
Old Thu, Mar-01-2018, 05:10:20 PM   #5
ApexRaceParts
TITEtec Stud Kit Wheel Locks prevent forced removal with a free-spinning ring around the edge.
Old Thu, Mar-15-2018, 07:11:37 PM   #6
ApexRaceParts
TITEtec OEM+ Wheel Locks protect your wheels while maintaining a factory appearance.
Old Thu, Aug-30-2018, 04:51:52 PM   #7
ApexRaceParts
Here's how the different styles of TITEtec wheel locks look on our EC-7 wheels:
Discussing ► New TITEtec Wheel Locks - Extended Length Wheel Locks in the E36 / E30 - Parts for Sale/Wanted Forum - Use this section to post parts for sale or wanted that are related to the E36 or E30 only. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
