Old Wed, Oct-12-2011, 07:56:51 PM   #1
KrazyKorean
KrazyKorean's Avatar
Reputation: 0 KrazyKorean is on a distinguished road
Talking Wheel and tires size question
Im deciding on getting the VB3's since I had them on my 335i and loved the look...
Was wondering will the 19x8.5 +20 and 19x10 +25 fit just fine?
Actually the rears will just wondering if the offest was too low for the fronts.
Ill be running on H&R sports, I dont want to run crazy camber or roll fenders.
Also will running the OEM Michelin Pilot Sport 225/40 and 255/35 be fine? Im thinking they would just cuz those tires are pretty wide and beefy for those sizes compared to other tires, like falken..
Thanks
Jump to top KrazyKorean is offline   Reply With Quote
Old Wed, Oct-12-2011, 08:30:03 PM   #2
ModBargains III
ModBargains III's Avatar
Reputation: 0 ModBargains III is on a distinguished road
Default Re: Wheel and tires size question
The offset on the front will be a bit to aggressive. I would suggest that if you want to have a no-hassle set up, that you get the ET40 up front and the ET25 on the rear if you want to go with a 10" VB3.
As for tire sizes, I would suggest running a 245/35-19 up front and a 275/30-19 in the back. This is pretty standard for those size wheels.
If you want to get a set, feel free to contact me directly via PM, email or call me direct at:
714.582.3330 Extension 8002 - Jurrian
Jurrian@modbargains.com
Elliott Goodman | Modification Expert | Elliott@ModBargains.com | (714) 582-3330 ext. 8011
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | KW Coilovers |
HRE Flow Formed Wheels | StopTech Group buy #2!
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm (PST)
Check out the Blog! or add me on Facebook! for daily updates and discounts!
Jump to top ModBargains III is offline   Reply With Quote
Old Wed, Oct-12-2011, 09:59:53 PM   #3
KrazyKorean
Really +40 in the front, seems like that would be too high, I want the flush flush look..
Old Wed, Oct-12-2011, 10:02:45 PM   #4
ModBargains III
If you want more flush than that, I would suggest going with Sportline CS.16's instead because the front offset is 35 instead of 40, but the rears don't come in a 10", only 9.5" is available at this time.
If you really want a 10" rear, then I would suggest getting VMR's and then adding spacers mainly because there isn't another 10" wide CSL replica wheel, and more importantly, you wont find a more aggressive offset than ET35 from sportlines, so it's totally up to you.
Old Wed, Oct-12-2011, 10:06:00 PM   #5
M3ANMACHINE
@natrajusa
M3ANMACHINE's Avatar
Take the advice from someone who has actually ran different setups.
Those offsets will be perfect if you want to be slightly conservative. You could even add a small spacer to the front if you wanted.
I ran the VB3's in 19x9.5 +22 with a 245/35/19 and 19x10 +15 with a 275/30/19.
Here's some pics.
2011 E90///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
APEX | BIMMERWORLD | COBY WHEEL | CORSA | H&R | MACHT SCHNELL | PEDALHAUS
2014 F15 X5 | Space Grey | M-Sport
Old Wed, Oct-12-2011, 10:42:21 PM   #6
KrazyKorean
Originally Posted by M3ANMACHINE View Post
Don't let sponsors try to convince you to buy their products when they don't know anything about proper fitment. Take the advice from someone who has actually ran different setups.
Here's some pics.
Man that looks sick. So even if I wanted to do my initial size I'll be fine.
How much camber did you run in the front?
Old Wed, Oct-12-2011, 11:00:05 PM   #7
M3ANMACHINE
@natrajusa
Yes, your initial size you stated would be 11mm less flush in front that what I have pictured.
In this pictures I am running approximately -2 degrees of camber.
Old Thu, Oct-13-2011, 12:17:11 AM   #8
KrazyKorean
Nice then Ill just stick with those sizes.. thanks man
Old Thu, Oct-13-2011, 12:58:33 AM   #9
M3ANMACHINE
@natrajusa
No problem. Good luck!
Old Thu, Oct-13-2011, 01:19:15 AM   #10
Shimmy23
Addicted
Shimmy23's Avatar
Reputation: 0 Shimmy23 is on a distinguished road
jesus dude... try the search
brandon
Jump to top Shimmy23 is offline   Reply With Quote
michelin pilot, tires, vmr, wheels
Discussing Wheel and tires size question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
