Old Mon, Aug-13-2018, 01:10:42 AM   #1
M3_Pilot
Default Popped Spot Weld
What's up everyone,
Washed and cleaned my car today. And my paranoia of racp problems seems to have become a reality whilst performing my checkup. My car already has tms plates installed so I figured the spot welds would be the Achilles heel. Honestly, I'm not too concerned as it's the first sign failure and I check it regularly. Here's the damage.
I'm ready to pull the trigger on a vincebar or cmp kit and do it myself. But I also wanna know if I could weld the crack?
Also can anyone confirm that this is a popped spot weld? Or is it an actual tear?
Thanks
Anthony
2004 Jet Black/Cinnamon 6MT
Old Mon, Aug-13-2018, 01:21:55 AM   #2
lmtfi
lmtfi's Avatar
Default Re: Popped Spot Weld
That looks like a tear. You need to strip the soundproofing all around it to see how far the problem goes (including hairlines).
Old Mon, Aug-13-2018, 01:27:12 AM   #3
M3_Pilot
Hmm, okay then. I'll strip more of it off. It was a big pain to cut off that little square which is why I didn't strip more earlier.
Old Mon, Aug-13-2018, 01:52:25 AM   #4
SQ13
Use a heat gun and metal scraper
Old Mon, Aug-13-2018, 02:33:36 AM   #5
lmtfi
lmtfi's Avatar
There is an art to removing it. Do NOT overheat the soundproofing layer. Just heat it enough to get a sharp putty knife under the edge and then heat only enough to try to lift it WHOLE - one width of the putty knife at a time.
Old Mon, Aug-13-2018, 03:51:52 AM   #6
M3_Pilot
Awesome, thanks for your advice! I'll keep the thread updated. As of now, if the rest of the RACP checks out good then I'm going to stop drill this tear, weld it, and then install a VinceBar. Sounds like a good resolution no?
Old Mon, Aug-13-2018, 05:56:56 AM   #7
You have any weird creaking or noise along with this?
Old Mon, Aug-13-2018, 07:14:22 AM   #8
L0ADED
L0ADED's Avatar
This is what it looks like when the damage gets more extensive:
Hopefully the top end reinforcement bars are the solution. It would suck if the load is transferred elsewhere and starts causing other problems.
Old Mon, Aug-13-2018, 02:14:53 PM   #9
M3_Pilot
No creaking or noises. I only discovered it because I pulled the trunk floor mat to take a quick look at the top side. I'm going to pull the rest of the sound proofing later today to see the extent of the damage.
Old Mon, Aug-13-2018, 02:52:53 PM   #10
Texaz3
2005 BMW E46 M3 RACP / Subframe Failure - Separation and Cracks - YouTube
Wow, scary!
Discussing Popped Spot Weld in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
