Old Fri, Dec-01-2017, 05:48:58 AM   #1
EKaru
EKaru's Avatar
Reputation: 766 EKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru PorshaEKaru Porsha
Default Evo E9x M3 buyers guide
Jump to top EKaru is offline   Reply With Quote
Old Fri, Dec-01-2017, 12:41:50 PM   #2
Cyrus
Reputation: 0 Cyrus has disabled reputation
Default Re: Evo E9x M3 buyers guide
Thanks Evo. Here's Cyrus' E90 M3 buying guide:
Don't buy one. They are boring.
2017 VW Golf R (DSG)
2014 Mazda MX-5 Club (manual, soft top)
Jump to top Cyrus is offline   Reply With Quote
Old Fri, Dec-01-2017, 01:00:29 PM   #3
e46Dawg
e46Dawg's Avatar
Reputation: 0 e46Dawg is a jewel in the rough
The bearing issue really sucks because there doesn't seem to be a proven fix. Buying one of these used means you had to really trust that the previous owner(s) let the car warm up properly and didn't beat on it too early. Even then, you may still have issues. It was part of the reason I ended up in a c63.
Jump to top e46Dawg is offline   Reply With Quote
Old Fri, Dec-01-2017, 02:38:06 PM   #4
LALaw
Reputation: 0 LALaw has disabled reputation
This doesn't sound reliable enough to be used as a daily driver
Jump to top LALaw is offline   Reply With Quote
Old Fri, Dec-01-2017, 02:58:00 PM   #5
Cyrus
In my opinion it is certainly not, especially if the object appears to be getting a used one at a good price, because the general maintenance is inconsistent with that idea.
But again the bottom line for me is I did not much like the way it drove.
Old Fri, Dec-01-2017, 03:49:20 PM   #6
Intredasting
You are now breathing manually
Intredasting's Avatar
Reputation: 0 Intredasting is on a distinguished road
It's very refined. Almost to a fault. Still better than an F80 though.
Jump to top Intredasting is offline   Reply With Quote
Old Sat, Dec-02-2017, 01:46:33 AM   #7
Rez
Rez's Avatar
I like it, have had 2, a manual and DCT. The other choices around are no better. I just can't deal with F80
Old Sat, Dec-02-2017, 02:20:53 AM   #8
keca10
Useful Posts: 5
keca10's Avatar
Reputation: 0 keca10 is a jewel in the rough
m3 forum Guide to buying E9X:
- 6 speed
- no sunroofs
- ZCP preferably
- 2009+
- no verts, E90 is best. E92 ok.
- make sure it’s babied
Jump to top keca10 is offline   Reply With Quote
Old Sat, Dec-02-2017, 02:20:55 PM   #9
mrgizmo04
mrgizmo04's Avatar
Exhaust note is pretty amazing, the rest not so much.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Sat, Dec-02-2017, 02:34:26 PM   #10
e46Dawg
e46Dawg's Avatar
Exhaust is blah.
Discussing Evo E9x M3 buyers guide in the Off Topic Forum - Place to discuss this and that. Note: We also have "request to join" forums: Guns and Fitness.
