Old Sun, Jun-09-2019, 04:49:14 PM   #1
Roofus
M3 Driver
Roofus's Avatar
Reputation: 0 Roofus is on a distinguished road
Default EDC strut nut stuck at top , cant get 10mm on.
I was reinstalling the strut nut on the front passenger side on an EDC strut and the nut got stuck at the top threads just high enough so that I can't get the 10mm far enough down to grab the teeth. (Just FYI, the EDC have the plastic connector to adjust stiffness in the middle, so I can't stick a hex into the strut tower. That's why the 10mm socket is used.) Trying to be really careful here so that I don't strip it. I was following bill's guide (http://www.billswebspace.com/M3HRSpringInstallation) using a 21mm wrench on the nut and the 10mm socket on the strut. (I added a pic of his method from his guide.) Any suggestions?
Jump to top Roofus is offline   Reply With Quote
Old Wed, Jun-12-2019, 10:14:25 PM   #2
sterile stork
durp durp
Reputation: 0 sterile stork has disabled reputation
Default Re: EDC strut nut stuck at top , cant get 10mm on.
I'd bet a quick burst with an air/electric impact gun could get the nut off and without damage to threads/strut. Alternatively have you tried a socket wrench? Maybe a couple "quick" and slightly-aggressive pulses could do it. Could even put a strap around the strut in the wheel well.
Jump to top sterile stork is offline   Reply With Quote
Old Sat, Jun-15-2019, 05:30:24 PM   #3
Roofus
M3 Driver
Roofus's Avatar
I picked up a new nut today because those have that soft metal interior that’s made to deform. So I’m not concerned about using the air gun to back off the old nut.
My real concern is not having something good to hold the piston shaft without marring it. I picked up a 300lb trigger clamp today. Fingers crossed that’ll do it. Unfortunately, while I can gently use some sand paper on the threads if there’s any damage, I couldn’t find a rethreader at HD for this size. So more fingers crossed the threads aren’t damaged.
Old Sat, Jun-15-2019, 06:55:38 PM   #4
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Do you have a dremel with a small cutting wheel? Just cut the nut on both sides.
Build Thread - S54 Vanos Thread - Hi-Temp Oring Kits!
BAVSOUND Stage 1 - UltraGauge - Valentine One - Orion V4's - ARC-8's
TTFS Engine/SMG Tune/CSL 255 - SGT Headers/Sect 1/SCZA - Evolve Eventuri
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - BWS 500S 9k/11k
Jump to top WOLFN8TR is online now   Reply With Quote
Old Sat, Jun-15-2019, 10:29:31 PM   #5
Roofus
M3 Driver
Roofus's Avatar
Got it. Got the grip clamp on the strut shaft and one pull on the gun knocked it loose. Looked like some strands of the deforming nut material (not sure what you call that) caked around the threads. But threads were in great shape. The new nut went right on. Tightened everything down and good to go. Alignment on Monday.
Went with the the H&R Sport Plus. Really think it turned out well and their tunes for EDC. Rear is just above the tire and front is about a half inch up. Not super dumped. Just has a nice look that got rid of the majority of the gap.
Glad to get everything buttoned up and not be spending my entire weekend with this. Thanks for the tips guys!
Old Tue, Aug-20-2019, 01:44:52 AM   #6
arianapham
Reputation: 0 arianapham is on a distinguished road
This was among the best posts from your team it let me learn many new things.
facebook entrar
Jump to top arianapham is offline   Reply With Quote
Discussing EDC strut nut stuck at top , cant get 10mm on. in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
