Old Sat, May-05-2018, 07:34:51 PM   #1
bmwstephen
Default steering wheel clock spring question
Just picked up a nice steering wheel with a clock spring intact. However I dunno how to tell if it is working as it should so I took a video of me turning it. It seems to only turn in one direction but if I try to turn it counter clockwise it stops. Any input?
Heres the video
https://youtu.be/4Y1BuAzBBwM
Jump to top bmwstephen is offline   Reply With Quote
Old Sat, May-05-2018, 08:14:29 PM   #2
Default Re: steering wheel clock spring question
That is how it works. It unlocks when installed. I'd suggest you stop turning it in one direction before you end up unwinding the entire thing. The design is a coiled up flat ribbon cable. If they left it free spinning it could end up unwound or over wound by someone playing with it.
The unlock is the white pivoting lever on the other side (wheel side). The steering shaft bolt depresses the mechanism.
Old Sat, May-05-2018, 08:27:50 PM   #3
bmwstephen
Noted thanks brett!
Old Sun, May-06-2018, 12:19:59 AM   #4
bmwstephen
Brett do you happen to know which year they also added the M tri color stitching on the wheels?
Old Sun, May-06-2018, 02:07:35 AM   #5
All M3 have Tri-Color.
Old Sun, May-06-2018, 02:26:54 AM   #6
bmwstephen
So is this one off a different car? There appears to be just black stitching
Old Sun, May-06-2018, 08:37:45 AM   #7
That would be from a non-M. I can’t tell but that may be the entirely wrong size too off an E39 (385mm versus E36 M3 375mm). Looking back at your video your clockspring is missing the wires too... so that is likely hosed.
Old Mon, May-07-2018, 01:12:12 AM   #8
frbz
That looks like the wheel of my E36 328is
Jump to top frbz is offline   Reply With Quote
Old Mon, May-07-2018, 01:01:51 PM   #9
Double E
Double E
Reputation: 0 Double E is on a distinguished road
That M badge looks a little odd too.
On my first 99 M3, the stitching was so dirty, the strings looked black. A wash revealed the colors but the leather was so bad I just got a new wheel.
'97 M3/2/5. Hellrot on Black ...and a racecar.
Jump to top Double E is offline   Reply With Quote
Old Mon, May-07-2018, 04:14:33 PM   #10
bmwstephen
That would be from a non-M. I canít tell but that may be the entirely wrong size too off an E39 (385mm versus E36 M3 375mm). Looking back at your video your clockspring is missing the wires too... so that is likely hosed.
Brett can these clock springs be refreshed or do they normally just get replaced? I just haven't come across any bmw e36 specific D.I.Y. I have seen older Porsche guys DIY rewind, lube up, and repair their clock springs but that's because they really have no choice given the limited parts
I do have a few lying around from other steering wheels that appear to be intact.
Discussing steering wheel clock spring question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
