Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Old Thu, Aug-20-2009, 05:25:54 AM   #1
z3m3conversion
Reputation: 0 z3m3conversion is on a distinguished road
Default Oil shoots out when dip stick is removed and blue smoke
Just purchased a Z3 with M3 E36 motor, the previous owner was not honest and did not allow me to test drive the car for more than 5 mins. Sold the car to me assuring the engine has no problems.
Right after I got the car, I noticed smoke from the exhaust, not knowing much about cars, I first suspected the head gasket, after some checks this was ruled out and now I believe it is burning oil.
Today after driving about 24 miles, i let it rest for some time and removed the dip stick, this is when oil rushed out. I do not think this is normal but was told by the previous owner that this is a high pressure engine and that I should let the engine rest long before taking the dip stick out.
a) is this normal? is it right that oil will rush out whent the dip stick is removed?
b) How can I tell if I am indeed burning oil, as I was also told that the smoke is probably burning of gas as the car might me running rich.
Please help - Thanks!
I
Jump to top z3m3conversion is offline   Reply With Quote
Old Thu, Aug-20-2009, 09:05:16 AM   #2
stussystatus
Reputation: 0 stussystatus is on a distinguished road
Blue smoke is oil burning.
White smoke is water/coolant burning.
Jump to top stussystatus is offline   Reply With Quote
Old Thu, Aug-20-2009, 01:40:43 PM   #3
z3m3conversion
Thanks much...since I am new to BMW engines.. is it TRUE that you should not remove the Dip stick when the engine is hot or else oil will shoot out - Thanks
Old Fri, Aug-21-2009, 07:31:56 PM   #4
yellow_m3
yellow_m3's Avatar
Reputation: 0 yellow_m3 is on a distinguished road
To answer your question, no that is not normal. When your rings are worn combustion pressure enters the crankcase and pressurizes the oil pan. I've never heard of hot oil shooting out of the dipstick tube, though. Bluish smoke in the exhaust is indicative of oil getting past the rings and into the combustion chamber. Take it to a shop and have it inspected.
Jump to top yellow_m3 is offline   Reply With Quote
Old Thu, Feb-24-2011, 03:27:59 PM   #5
englishtom1596q
englishtom1596q's Avatar
Default Re: Oil shoots out when dip stick is removed and blue smoke
could also be a breather problem. all engines with have crankcase ventilation or a breather. if this becomes clogged it can also pressurize the crankcase causing oil to burn. don,t really know where the breathers are on these engines though.
and as yellow_m3 said it could also be warn piston rings allowing combustion gases to pass into the crankcase. a cylinder leakage test would be the best indication of this.
Old Thu, Feb-24-2011, 04:11:09 PM   #6
M3n00b
M3n00b's Avatar
North Korea
Never buy any BMW without a pre-purchase inspection with compression/leakdown test. No, nothing you posted is normal.
Old Thu, Feb-24-2011, 04:50:12 PM   #7
deilenberger
deilenberger's Avatar
This is true.. but bet he figured it out by now (the thread was 2 years old..)
  • 2011 Lexus RX-350. SWMBO's toy.
Old Thu, Feb-24-2011, 04:59:01 PM   #8
M3n00b
M3n00b's Avatar
North Korea
Old Mon, Sep-23-2013, 01:49:24 PM   #9
circuit_icon
circuit_icon's Avatar
Reputation: 0 circuit_icon is on a distinguished road
Always do a compression test before buying a used car.
Sounds to me like you have too much crank case pressure. In your case, this is most likely caused by a sealing issue with the piston and/or rings. Chances are at least one of them is broken. Do a compression test and report back. Be sure to pull the fuel pump fuse while doing the test.
Jump to top circuit_icon is offline   Reply With Quote
Old Sun, Oct-13-2013, 06:03:30 AM   #10
riskee
riskee's Avatar
Reputation: 0 riskee is on a distinguished road
now its 4 years old
04 m3 smg2 alpine white on black not stock ///M track mode and csl smg software and akg bushings subframe reinforced, oem square 19s, evo sport headers custom tune, pss10 coilovers and lots of alcantra XV111 R.I.P my partner
09 e60 m5 space grey fully loaded (sharky)
Jump to top riskee is offline   Reply With Quote
blue, dip, oil, removed, shoots, smoke, stick
Discussing Oil shoots out when dip stick is removed and blue smoke in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
