Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Old Tue, Oct-23-2007, 12:45:10 AM   #1
stevec
stevec's Avatar
Reputation: 0 stevec is on a distinguished road
Default Rough idle common in M3
Reasonably new owner 1998 sedan. It idles a bit rough at stop. I was told this is common ( yes and I was born Yesterday) where should I look first? I added a cold air intake but it was doing this before the add on. Some days it runs like a scared rabbit and some days it is a dog... wonder if it is related to the idle. Thanks for your input and patience!
Jump to top stevec is offline   Reply With Quote
Old Thu, Feb-02-2012, 07:52:08 AM   #2
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
Default Re: Rough idle common in M3
This is definitely not common, my 02/98 M3 idles smooth.
Did you measure for air leaks in intake system, temperature sensors for air intake and coolant?
Has the crankshaft position sensor already been replaced on your 1998 M3 under the recall against a new one with 12V instead of the old 5V version plus a new harness for that? If not, or not known, check with your dealer if there are any recalls open.
Jump to top Eric M3 is offline   Reply With Quote
Old Sat, Jun-29-2013, 07:13:59 PM   #3
kimokk
Reputation: 0 kimokk is on a distinguished road
Does the recall apply to '97's (10/96 build) too?
Jump to top kimokk is offline   Reply With Quote
Old Sat, Jun-29-2013, 09:17:45 PM   #4
drummer boy04
drummer boy04's Avatar
Reputation: 0 drummer boy04 is on a distinguished road
how's your gas consumption?
I had a bad o2 sensor that caused a bad idle, and poor performance and gas mileage...but then again, my car threw a code as well...
Just another suggestion. I would check what Eric M3 said first
'99 ///M3 coupe Alpine White/Magma (no-sunroof)
__________________________________________
Jump to top drummer boy04 is offline   Reply With Quote
95 M3 Rough Idle.....Sometimes mikesblum3 E36 M3 (1992-1999) 1 Sun, Jul-01-2007 09:53:33 PM
Rough idle when cold, slightly rough warm idle woky E36 M3 (1992-1999) 8 Thu, Mar-29-2007 12:42:56 PM
Are rough starts common? kvoss E46 M3 (2001-2006) 7 Fri, Aug-22-2003 08:32:39 PM
rough idle on 95 M3 ksabey E36 M3 (1992-1999) 13 Wed, May-14-2003 12:17:03 PM
95 Rough Idle BubbaJudge E36 M3 (1992-1999) 4 Sat, Jan-25-2003 08:20:13 AM
Discussing Rough idle common in M3 in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
