Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Closed Thread
Old Mon, Jul-21-2003, 02:21:00 PM   #31
97BLKM3COUPE
Reputation: 0 97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute
Rondawg,
The first intake is a short ram intake and does not have a heatshield. It is not worth getting it.
The second one is a bit more interesting, but the filter does not look washable. and because it is wrapped in metal, it will not allow as much air in as a straight K&N filter.
Pay the extra amount and get a real one.
Jump to top 97BLKM3COUPE is offline
Old Tue, Jul-22-2003, 06:15:08 PM   #32
WytLytnyn
WytLytnyn's Avatar
Reputation: 0 WytLytnyn is on a distinguished road
Yeah, I'd stay with the stock airbox over that.....
Current: 2005 Titaniumsilber M3 Coupe
Dinan CAI/Exhaust/Stage 3 suspension, spherical bearings in rear trailing arms
UUC EVO 3 + DSSR
Look Ma! No sunroof! "Wood" trim! Unpowered Cloth Seats! NAV!
Michelin Pilot Super Sports on OEM 19's
"If everything is under control, you are just not driving fast enough!" - Sir Stirling Moss
Jump to top WytLytnyn is offline
Old Wed, Jul-23-2003, 02:27:28 AM   #33
genner21
genner21's Avatar
Reputation: 0 genner21 is on a distinguished road
Here is what you'll get when you order a PAR INTAKE
95 Cosmo BMW M3
Jump to top genner21 is offline
Old Wed, Jul-23-2003, 02:30:13 AM   #34
genner21
genner21's Avatar
And Here is how it looks like Installed. I tested the Car already and it I give it a thumbs up on how it sounds. It was easy to install. I didn't take pics while installing it because when you order it, it will come with instructions that have pics. I recomend it.
95 Cosmo BMW M3
Old Fri, Jul-25-2003, 02:23:54 AM   #35
BMW M Power
Senior Member
BMW M Power's Avatar
Reputation: 0 BMW M Power is on a distinguished road
a little OT, but it has some connection. Have any of you guys had problems with your warranty when the CAI is intstalled?
99 Silver M3: GC Race Coilovers (500/550), UUC Sways, JTD Bar, UUC Stage2 Clutch/Flywheel, M50 Manifold, ASC Delete, Cosmos CAI, Custom Exhaust, UUC UDP's, UUC SSK/RK3, ZKW w/dde enhanced, V2 Splitters, Black Kosei K1 17x8.5 with 255/40 Kumho MX
Jump to top BMW M Power is offline
Old Fri, Jul-25-2003, 05:24:36 AM   #36
PurpleM3Pursuit
E36 on the way out... E92 on the way in..
PurpleM3Pursuit's Avatar
Reputation: 578 PurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond repute
there is no way on gods green earth that they can prove the intake caused a problem.. not possible.. so no.. no probs here..
Alex... or PM3P... being a good Leader for YOU!
E92 M3 AW/BL Competition
BMWCCA# 368302
Also in the fleet:
'75 Porsche 911 Carrera
'85 Chevrolet Camaro Z28
'87 Porsche 951
'95 BMW 325i DM #422
'15 F150 EB SCrew
Jump to top PurpleM3Pursuit is offline
Old Fri, Jul-25-2003, 03:28:05 PM   #37
BMWGuy206
Reputation: 0 BMWGuy206 is on a distinguished road
Lets say you got a check engine light with a fault code of Air Mass Sensor or mixture deviation on cylinder 1-3 or 4-6. If the dealer wants to be an ass they can blame the intake kit for those faults and will not touch your car unless you put the stock air box back in and then they can start proper diagnosis. They will also write down on their notes that you installed an aftermarket intake kit which BMW will read and record.
Jump to top BMWGuy206 is offline
Old Fri, Jul-25-2003, 04:56:41 PM   #38
97BLKM3COUPE
In that case you may be correct. If the dealer can prove (or come close to it) that the intake caused the problem, then you are screwed.
Best bet is to put the factory airbox when you take your car in for a problem while you still have a warranty. Especilly if it is a problem that may be attributed to the intake. Even though a properly installed and maintained intake could not cause a problem (aside from hydro-lock).
Old Fri, Jul-25-2003, 07:23:38 PM   #39
98technovlt
emineminem
Reputation: 0 98technovlt is on a distinguished road
Just a note about heat transfer and the intake tube material. When i installed my PAR i had some concerns that the metal intake tube would transfer heat to the intake charge, unlike the carbon fiber based ones. So when i installed it i drove around for a while and then felt the tube to see if it was hot. It was around 99 degrees that day and i drove pretty hard for about thirty minutes (had to check out the performance!) then came home. The last mile i had to slow to 20 mph to get to my home. When i reached in and felt the tube it was cool to the touch! I know that it is not possible but it felt cooler than ambient temp! Anyway, i realize that i was not sitting in traffic or idling long enough to deal with max heat soak but i was surprised....Additionally, the tube is constructed from thin metal that, if heated, would not require a tremendous amount of air to pull the heat back out. Has anyone else "felt" their intake tube? (OK, i realize that i will get some interesting responses to that!)
Jump to top 98technovlt is offline
Old Fri, Jul-25-2003, 07:49:24 PM   #40
97BLKM3COUPE
My tube is cool towards the filter, but as you get close to your MAF it gets a bit warm.
I think this is normal unless you had a heatshield for the MAF too.
Next time, feel the MAF after you get out and the rubber boot after that towards the engine.
They are both pretty hot. This is where the heat soak will happen and unless my car is odd, everyone should have the same problem.
Closed Thread
E36 information - towing Dave Crump E36 M3 (1992-1999) 5 Sat, Aug-04-2007 07:41:18 AM
FS - Conforti E36 Intake. def328 Parts for Sale/Wanted 13 Sat, Apr-14-2007 04:44:05 AM
Wtb E36 M3 Chip Or Intake koolikdat Parts for Sale/Wanted 0 Wed, Apr-20-2005 05:01:09 PM
Does the E36 come with AIR INTAKE? PiZark E36 M3 (1992-1999) 7 Fri, Sep-10-2004 06:30:17 PM
looking to buy an e36...looking for information imaboa E36 M3 (1992-1999) 2 Tue, Aug-17-2004 04:52:22 AM
Discussing (E36) Intake information in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
